Posted February 25, 20178 yr comment_513816 Pros: Car has been in Murrieta, CA from 1993 unitl 2010; Texas until 2016. Been in TN for one year. 3.1 stroker setup with 1000 miles since build. Z Therapy carbs with needle setup for 3.1 stroker engine. Light wire harness relay upgrade. Z Specialists 125 amp alternator. S2000 seats. Innovate O2 wideband. Cold air intake. 79 280zx 5 speed that was overhauled 2014. Fuel pump inertia cutoff switch. USB wired in glove box. Floor pans are solid. Floor from firewall to rear was primed and then Fatmat installed. Toyota 2 piston calipers with 15/16 master cylinder. Just replaced clutch master cylinder. Cons: Front end is loose. Rod ends were replaced in 2011 so I am thinking the rack and pinion needs reworked. The paint job was done in 1993 and showing its age. A few rust bubbles on the top of hatch. No rust inside the rear hatch area. A few dings underneath from idiot at tire shop not hitting the jack point. Speedometer needle doesn't move. Odometer works. The stroker engine setup: N42 block L28 293547 overbore 3mm KA24E PISTONS ITM RY6660 CUT .5mm by machine shop N42 head mildly ported and polished; gasket matched Cosmetic head gasket 1.2mm Isky L480 cam 480 lift 280 duration 71 240z connecting rods MSA 6-1 header 2 ½ “ Magnaflow exhaust Canon Intake 1979 280zx distributor welded to 15 degree max advance (15 idle to 30 @ 3500 rpm). Vacuum plugged. MSD 6AL and MSD tach adapter 3 ohm Petronix flamethrower Taylor 8mm spark plug wires Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/ Share on other sites More sharing options...
February 25, 20178 yr comment_513822 My guess is that the motor is worth 8 to 10 thousand.....get rid of that ridiculous hood and it'll look civilized too! Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/#findComment-513822 Share on other sites More sharing options...
February 25, 20178 yr comment_513823 57 minutes ago, Diseazd said: My guess is that the motor is worth 8 to 10 thousand.....get rid of that ridiculous hood and it'll look civilized too! Funny I love the hood! That center peice is worth a couple hundred bucks. Is there an electric fuel pump even with the mechanical one? GLWS. I think it should sell pretty quick. Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/#findComment-513823 Share on other sites More sharing options...
February 25, 20178 yr comment_513825 1 hour ago, Diseazd said: My guess is that the motor is worth 8 to 10 thousand.....get rid of that ridiculous hood and it'll look civilized too! Dave Rebello will built that engine for around $7,800 with not core parts, if I am not mistaken. I would like to know what the dyno output is on this engine. Looks like a good deal if that is the style Z you are interested in. Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/#findComment-513825 Share on other sites More sharing options...
February 26, 20178 yr comment_513832 6 hours ago, JLPurcell said: Dave Rebello will built that engine for around $7,800 with not core parts, if I am not mistaken. I would like to know what the dyno output is on this engine. Looks like a good deal if that is the style Z you are interested in. Pretty darn close, ask me how I know. My motor is very close except for the cam (Rebello custom vs Isky) and Dave estimates it a 285hp+ on SU's and he claims 300+ on triples. Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/#findComment-513832 Share on other sites More sharing options...
February 26, 20178 yr comment_513833 16 minutes ago, Kurbycar32 said: Pretty darn close, ask me how I know. My motor is very close except for the cam (Rebello custom vs Isky) and Dave estimates it a 285hp+ on SU's and he claims 300+ on triples. Sounds good, I am considering having Dave build me a 2.7 stroker (purist engine) using my numbers matching engine. He suggested I go for the 3.1 and sit my engine aside. This is how I have some Idea of the cost. Still undecided, but have all summer to consider it. JLP Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/#findComment-513833 Share on other sites More sharing options...
February 27, 20178 yr Author comment_513888 That hood gets a mixed review. No middle ground from the crowd.....they just love it or hate it! Also here are a few shots of the Magnaflow exhaust. Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/#findComment-513888 Share on other sites More sharing options...
February 27, 20178 yr Author comment_513889 I replaced the stock fuel pump with a nice quiet 5 PSI Carter pump and wired in the inertia cutoff switch. Just block the mechanical and it's ready for a set of Weber DCOEs. Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/#findComment-513889 Share on other sites More sharing options...
February 27, 20178 yr comment_513952 Have you considered posting it on Bring a Trailer? Those guys are nuts for Z's lately, ill probably post mine up there this summer. If you put my username in there (kurbycar32) I think they send me $100 Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/#findComment-513952 Share on other sites More sharing options...
March 7, 20178 yr comment_514699 Are you in the Army by chance? I was stationed at Ft. Campbell for 4 years Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/#findComment-514699 Share on other sites More sharing options...
March 7, 20178 yr Author comment_514704 Retired US Army. Working on FTCKY. Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/#findComment-514704 Share on other sites More sharing options...
March 8, 20178 yr comment_514715 On 25/02/2017 at 0:59 PM, Diseazd said: My guess is that the motor is worth 8 to 10 thousand.....get rid of that ridiculous hood and it'll look civilized too! That much money with only mild port work? I don't see it. With those carbs, that camshaft, so little headwork, and a so-so exhaust, I can't see the engine putting out much more than 200hp. There is value in the short block due to the large bore and v07 crank, but with cheap ITM cast pistons, it's not exactly a Rebello block. If selling used, I'd think it would go for maybe $3k. If it was fully ported, forged pistons, triple Mikuni carbs, a proper performance header, and a dyno sheet showing what it puts out, then $6k, maybe a little more. All of this said, at $12,000 it's a very nice, and solid, looking car at a great price. Should sell quickly! Link to comment https://www.classiczcars.com/forums/topic/57133-sold-1974-260z-rls30016515-31-stroker-for-sale-1199900-clarksville-tn/#findComment-514715 Share on other sites More sharing options...
