Posted February 28, 20178 yr comment_513986 I have my front suspension all apart except for the tie rod ends. I probably should have broken the tie rod end locking nuts loose before I took it all apart, now it's hard to get a good hold on it. I need to confirm which direction to turn the lock nut, on the passenger side I'm turning it right to left. To brake it loose. On th driver side I understand it is a reverse thread so I'm thinking left to right. Is that right? thanks Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/ Share on other sites More sharing options...
February 28, 20178 yr comment_513988 With the suspension together on car, you attach wrench from bottom and push both locknuts towards the rear of car to loosen. Hope that explains it enough for you to figure out. Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/#findComment-513988 Share on other sites More sharing options...
February 28, 20178 yr Author comment_514025 Perfect, thanks on the direction of spin. I think I'm going to finish the refresh put the suspension all back together in order to get the tie rod stable enough to get some leverage on it. Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/#findComment-514025 Share on other sites More sharing options...
February 28, 20178 yr comment_514033 I used a 24" pipe wrench on mine and a crescent wrench on the square at the end of the threads. Laid it on the floor and stood on the handle, my bench vise wasn't working. It was lifting my my work bench. I had turned it the wrong way until it was too tight. Now I know one's reversed threaded. Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/#findComment-514033 Share on other sites More sharing options...
February 28, 20178 yr comment_514036 34 minutes ago, siteunseen said: I used a 24" pipe wrench on mine and a crescent wrench on the square at the end of the threads. Laid it on the floor and stood on the handle, my bench vise wasn't working. It was lifting my my work bench. I had turned it the wrong way until it was too tight. Now I know one's reversed threaded. I love that you are so blatantly honest Cliff.....the rest of us screw up all the time, we just don't admit it!!! You've got no pride.....I'd love to have a beer with you sometime....Hell maybe 5 or 6! Guy. Edited February 28, 20178 yr by Diseazd Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/#findComment-514036 Share on other sites More sharing options...
February 28, 20178 yr comment_514041 What you see is what you get. I can't stand pompous people, although my life is full of them, being full of themselves. I'm the first to point out my mistakes and the first to correct them. Southern boy and very proud to say that. Thank you for the compliment. Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/#findComment-514041 Share on other sites More sharing options...
February 28, 20178 yr comment_514051 2 hours ago, Diseazd said: You've got no pride... I've got no shame. Very much pride in my Z. Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/#findComment-514051 Share on other sites More sharing options...
March 1, 20178 yr comment_514058 2 hours ago, siteunseen said: What you see is what you get. I can't stand pompous people, although my life is full of them, being full of themselves. I'm the first to point out my mistakes and the first to correct them. Southern boy and very proud to say that. Thank you for the compliment. I take pride in my mistakes. Those are opportunities to learn. Sometimes I learn that I can be pretty stupid. Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/#findComment-514058 Share on other sites More sharing options...
March 1, 20178 yr comment_514060 7 minutes ago, SteveJ said: I take pride in my mistakes. Those are opportunities to learn. Sometimes I learn that I can be pretty stupid. My saying at work is "tuition". When we mess something up, break something or learn the hard way we call that "tuition" ie. the cost of learning... Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/#findComment-514060 Share on other sites More sharing options...
March 1, 20178 yr comment_514074 My thinking, "get out of the way, I'll do it" then I break it. But I'm getting older and finally learning some things. Working on these 40 year old plus cars is a great teacher of patience and asking for help, something I've never known. Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/#findComment-514074 Share on other sites More sharing options...
March 1, 20178 yr comment_514075 1 hour ago, SteveJ said: I take pride in my mistakes. Those are opportunities to learn. Sometimes I learn that I can be pretty stupid. I read something the other day, "he's working at a Doctorate level..." I love it! Y'all all have good "tuition". Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/#findComment-514075 Share on other sites More sharing options...
August 10, 20195 yr comment_581646 On 2/27/2017 at 10:04 PM, gundee said: With the suspension together on car, you attach wrench from bottom and push both locknuts towards the rear of car to loosen. Hope that explains it enough for you to figure out. I hope I'm doing this right. With me standing over the steering rack that's laying on the floor, oriented like it came out of the car, does that mean I put the wrench on the lock nuts from above, and pull towards the front of the car? Thanks! Link to comment https://www.classiczcars.com/forums/topic/57148-hints-on-removing-stuck-locknut-on-tie-rod-ends/#findComment-581646 Share on other sites More sharing options...
