March 4, 20178 yr comment_514453 No offense, but there's a lot of distance between your first post and the one above. You already have a custom Toyota engine to Nissan transmission adapter, but you're concerned about a "transmission bracket" and don't know how to get an LSD in to your car? The elements of the story are discordant. Why don't you just use a IJZ 5 speed, the R154? (I had to do a Google to be sure about the R154. Not a 1JZ expert). How about a picture of the adapter plate, mounted up? We all love a good piece of machining. Link to comment https://www.classiczcars.com/forums/topic/57167-rear-subframe-conversion/?&page=3#findComment-514453 Share on other sites More sharing options...
March 5, 20178 yr Author comment_514454 Yea sorry for the mess I was just looking for a rear sub because I will be getting a custom driveshaft made but was thinking if I can use a z rear end. But will upload some pics of the adapter and custom flywheel I had to use too mate them Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57167-rear-subframe-conversion/?&page=3#findComment-514454 Share on other sites More sharing options...
March 5, 20178 yr Author comment_514475 On 3/4/2017 at 11:45 PM, Zed Head said: No offense, but there's a lot of distance between your first post and the one above. You already have a custom Toyota engine to Nissan transmission adapter, but you're concerned about a "transmission bracket" and don't know how to get an LSD in to your car? The elements of the story are discordant. Why don't you just use a IJZ 5 speed, the R154? (I had to do a Google to be sure about the R154. Not a 1JZ expert). How about a picture of the adapter plate, mounted up? We all love a good piece of machining.The reason y I didn't use a r154 is because the price for one is way to much, when I can use a 350z 6speed and make the same amount of power as if I was using the r154. Also I already had the 350z sitting around so I decided to put it to use will post some pics of the 1jzgte mate with 350z tomorrow if I get a chance Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57167-rear-subframe-conversion/?&page=3#findComment-514475 Share on other sites More sharing options...
