Prob been covered before, I searched found some old data.
I keep putting off doing my trans swap (rear main, clutch, trans swap 5 for a 4 speed) due to fear of the unknown.
anyway looking for good shop that knows how to work on old Z's (1975 280z). Found a website for Z tech in longwood FL.
any others, looking for feed back on Z tech or other shops for this kind of work.
https://www.classiczcars.com/forums/topic/57176-orlando-fl-shop/
will do, plan to go some time next week. I attempted to get started on the trans swap, car on jacks, penetrating oil on exhaust studs (remove exhaust pipe for access) impact gun, promptly snap off nut.... enough of that I will take it in and see what its going to cost. I prob should have heated with oxy/ace torch, all I had was a propane, not hot enough i guess. Anyway enough of that.
I will check them out and let you know. I would have thought there would be more folks here that have used them.
