Brake light not working
nahurry
Where are you located?
It would be unusual for there to be an issue with the turn signal after Dave reconditioned it, but it is not impossible. The turn signal is the point where the brake light circuit and turn signal circuit meet that could cause the issue that you describe.
Fortunately a meter and knowledge of the circuits can give us a more definitive answer.
I will check next time I'm off work. I work 3rd
