Posted March 5, 20178 yr comment_514484 My left side brake light is not working. Good bulbs, good fuse, like new bulb harness. The parking light works on that side as does the turn signal, but no brake light. My car is a 73 240Z. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/ Share on other sites More sharing options...
March 5, 20178 yr comment_514489 It's probably the turn signal switch. https://fiddlingwithzcars.wordpress.com/2013/01/20/hazard-switch-brake-light-turn-signal-circuit-analysis/ https://fiddlingwithzcars.wordpress.com/2012/12/04/turn-signal-repair/ I'm two hours away if you want a definitive diagnosis. Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/#findComment-514489 Share on other sites More sharing options...
March 5, 20178 yr comment_514495 @nahurry what color is your car? Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/#findComment-514495 Share on other sites More sharing options...
March 6, 20178 yr Author comment_514540 On 3/5/2017 at 5:26 PM, Patcon said: [mention=2589]nahurry[/mention] what color is your car?Charcoal MetallicSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/#findComment-514540 Share on other sites More sharing options...
March 6, 20178 yr Author comment_514541 It's a new T/ S rebuild by Dave IrwinSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/#findComment-514541 Share on other sites More sharing options...
March 6, 20178 yr Author comment_514542 On 3/5/2017 at 2:52 PM, SteveJ said: It's probably the turn signal switch.https://fiddlingwithzcars.wordpress.com/2013/01/20/hazard-switch-brake-light-turn-signal-circuit-analysis/https://fiddlingwithzcars.wordpress.com/2012/12/04/turn-signal-repair/ I'm two hours away if you want a definitive diagnosis.Where are you located?Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/#findComment-514542 Share on other sites More sharing options...
March 6, 20178 yr comment_514543 Gainesville, GA Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/#findComment-514543 Share on other sites More sharing options...
March 6, 20178 yr Author comment_514545 Ok, I could make that trip Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/#findComment-514545 Share on other sites More sharing options...
March 6, 20178 yr Author comment_514546 On 3/6/2017 at 3:11 AM, nahurry said: It's a new T/ S rebuild by Dave IrwinZs ondabrainSent from my iPhone using Classic Zcar Club mobileSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/#findComment-514546 Share on other sites More sharing options...
March 6, 20178 yr comment_514552 It would be unusual for there to be an issue with the turn signal after Dave reconditioned it, but it is not impossible. The turn signal is the point where the brake light circuit and turn signal circuit meet that could cause the issue that you describe. Fortunately a meter and knowledge of the circuits can give us a more definitive answer. Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/#findComment-514552 Share on other sites More sharing options...
March 6, 20178 yr Author comment_514574 On 3/6/2017 at 3:40 AM, SteveJ said: It would be unusual for there to be an issue with the turn signal after Dave reconditioned it, but it is not impossible. The turn signal is the point where the brake light circuit and turn signal circuit meet that could cause the issue that you describe. Fortunately a meter and knowledge of the circuits can give us a more definitive answer.I will check next time I'm off work. I work 3rdSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/#findComment-514574 Share on other sites More sharing options...
March 7, 20178 yr comment_514606 @nahurry Thanks for the reply. I was wondering what color your car was because I saw a Z the other day on the south end of Woodruff rd but it was orangish... Link to comment https://www.classiczcars.com/forums/topic/57188-brake-light-not-working/#findComment-514606 Share on other sites More sharing options...
