Posted March 11, 20178 yr comment_515073 What's the order I stick the spark plug cables into my distributor cap? Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/ Share on other sites More sharing options...
March 11, 20178 yr Author comment_515074 It's a 1979 280zxSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/#findComment-515074 Share on other sites More sharing options...
March 11, 20178 yr comment_515082 153624 CCW Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/#findComment-515082 Share on other sites More sharing options...
March 11, 20178 yr Author comment_515087 Do you have a picture I can follow?Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/#findComment-515087 Share on other sites More sharing options...
March 11, 20178 yr comment_515098 Theres a vertical line on the distributor cap that is #1. Google 280z firing order then click IMAGES. Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/#findComment-515098 Share on other sites More sharing options...
March 11, 20178 yr comment_515099 There's a ton on the internet. But many of these old engines have been worked on and made to run with the distributor off a tooth or two. The best thing to do is to set the timing mark on the damper pulley to zero, on the compression stroke of cylinder #1, then set plug wire #1 in the cap to wherever the rotor under the distributor cap is pointed. Then plug in the rest of the wires in a counterclockwise direction,in the order I showed. People have wasted hours and days of time setting their wires the way the factory did, only to find that their distributor wasn't the way it was when it left the factory. If you want specific help post some pictures after you set the timing mark to zero. Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/#findComment-515099 Share on other sites More sharing options...
March 11, 20178 yr Author comment_515107 Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/#findComment-515107 Share on other sites More sharing options...
March 11, 20178 yr Author comment_515108 That's really the only thing I foundSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/#findComment-515108 Share on other sites More sharing options...
March 12, 20178 yr comment_515145 I think he meant posting pics of your engine and dizzy so we can see itSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/#findComment-515145 Share on other sites More sharing options...
March 16, 20178 yr Author comment_515561 Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/#findComment-515561 Share on other sites More sharing options...
March 16, 20178 yr comment_515564 On 3/16/2017 at 6:21 PM, Sigma358 said: Sent from my iPhone using Classic Zcar Club mobile Wrong side. Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/#findComment-515564 Share on other sites More sharing options...
March 16, 20178 yr comment_515577 Get a pic that shows both sides if you can. Preferably the distributor and wires. Looks like a holy mess in there. Edited March 16, 20178 yr by rcb280z Link to comment https://www.classiczcars.com/forums/topic/57239-spark-plug-order/#findComment-515577 Share on other sites More sharing options...
