Hole in side of block??
TheErictag
On 3/25/2017 at 8:52 PM, TheErictag said:
So what type of hoses should I use when I get rid of the can.. I'll follow advice and get a pcv system functioning. But first things first what are the correct types of hoses to run for this considering I've got those gawdy looking ones now!!
I use reinforced forced Hi Temp Silicon hose from Goodyear. Many Big Rig truck parts supplier carry it.. Good quality Silicone hose can be used for both coolant and Vent/PCV lines. Hi-Temp Silcone hose is especially good around exhaust manifolds and Turbochargers.
You can also use the re-inforced Silicon Coolant hose from SiliconeIntakes.com. Works fine for vent hoses and PCV hoses. Available in different diameters and colors.
 http://www.siliconeintakes.com/electric-radiator-cooling-fans/reinforced-silicone-heater-hose-p-642.html
  • Who's Online   0 Members, 0 Anonymous, 363 Guests (See full list)
