April 26, 20177 yr comment_519199 On 4/26/2017 at 3:55 PM, jalexquijano said: Nick, I already had the msa Premium exhaust kit installed. I did noticed there is some detonation when i let the gas pedal go and more pronounced if i go down a hill. Is this normal?? Both of my 72 round 3 screws SU CARBS are tuned and balanced correctly. If i lean the mixture i will have detonation at the intake. Are the gasket sold by MSA good enough? My original stock system was 2". THis one is 2.5"I would notice when the car was cool I would get some pooping but once it warmed up all was well. I would stand behind the gasket provided by MSASent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519199 Share on other sites More sharing options...
April 26, 20177 yr Author comment_519212 So these gaskets are really of good quality? The popping is only on deceleration and becomes more accentuated when the car goes down a hill with the foot off the accelerator. Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519212 Share on other sites More sharing options...
April 26, 20177 yr comment_519213 On 4/26/2017 at 8:32 PM, jalexquijano said: So these gaskets are really of good quality? The popping is only on deceleration and becomes more accentuated when the car goes down a hill with the foot off the accelerator.Personally I would probably find a better brand because if I'm not mistaken MSA sends a cheap cardboard type gasket.I haven't had any leaks but maybe look for a better brand gasket for 2.5 inch exhaust and you'll probably be better off in the long run if it's a daily driver. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519213 Share on other sites More sharing options...
April 26, 20177 yr comment_519218 Odds are you have blown out a section of your gasket. Dave Rebello and I were just discussing this. He recommends a for exhaust red/orange high temp etc in replacement of the gasket. I did ask him about a copper racing gasket and he has not tested them. They are about $50Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519218 Share on other sites More sharing options...
April 26, 20177 yr comment_519219 Sorry. Type error. RTV not ect Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519219 Share on other sites More sharing options...
April 26, 20177 yr comment_519220 https://zcardepot.com/engine/engine-rebuild/copper-racing-manifold-gasket-intake-exhaust-240z-280z.htmlSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519220 Share on other sites More sharing options...
April 27, 20177 yr Author comment_519282 On 4/26/2017 at 8:40 PM, Nick0227 said: Personally I would probably find a better brand because if I'm not mistaken MSA sends a cheap cardboard type gasket. I haven't had any leaks but maybe look for a better brand gasket for 2.5 inch exhaust and you'll probably be better off in the long run if it's a daily driver. Sent from my iPhone using Classic Zcar Club mobile Where do i get these high quality 2.5 diameter gasket? Edited April 27, 20177 yr by jalexquijano Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519282 Share on other sites More sharing options...
April 27, 20177 yr comment_519312 I have the MSA stock manifold kit and really love it. Sounds much better than my twice pipe setup and bolted up nicely. Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519312 Share on other sites More sharing options...
April 27, 20177 yr Author comment_519315 i love it too!! but have some popping on deceleration when letting the gas pedal go. Im afraid i can damage the engine and hence i have been advised the unión gaskets are not of high quality. Where do i get the nissan quality gaskets? Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519315 Share on other sites More sharing options...
April 27, 20177 yr comment_519327 The popping on deceleration is unburnt fuel leaving the combustion chamber into the exhaust system & combusting (burning) due to the heat in the exhaust. I solved mine by removing all of my smog gear, capping off the air galley and leaning out the carbs.Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519327 Share on other sites More sharing options...
April 27, 20177 yr Author comment_519330 air galley? lean more tan 2.5 turns clockwise which is the starting point? Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519330 Share on other sites More sharing options...
April 28, 20177 yr comment_519380 The air galley is the device that the smog pump pushes fresh air into the exhaust manifold with. Most of them are leaking or damaged by now. Link to comment https://www.classiczcars.com/forums/topic/57338-replacing-exhaust-system-on-my-72-240z-from-the-manifold-to-the-back/?&page=3#findComment-519380 Share on other sites More sharing options...
