240Z fan radiator
datsunnyit
Hi all
the standard 240Z fan clutch for radiator fails.
Is necessary replace with new modern fan or 2 fans with thermostat.
Any experience, suggestions link for vendors.
The electromechanical thermostat or the electronic sensor (NTC), at what temperature has to be calibrated?
If a fan is used as recommended diameter?
If two fans who recommended diameter?
you have pictures?
other important info ?
thanks
Did it run hot before you found the fan clutch failure?  Can you replace the fan clutch?
I replaced both fan clutches on the two 240s I've had along with a new water pump and thermostat.  The needle points straight down, south.  175 fahrenheit.
The one I have now has a 280Z radiator and full plastic shroud off a 280ZX.  It runs 170 fahrenheit.
It's a lot easier to install a 280Z radiator than more electronics like the fans, to me.  The only drawback is the 280Z radiator hangs down 2 or 3 inches more.
  • Who's Online   2 Members, 0 Anonymous, 360 Guests (See full list)
