Wow not even half way there
P the Z
[mention=31839]P the Z[/mention]
Be very careful blasting the car yourself. It is very easy to ruin these cars if you aren't careful! The metal is exceedingly thin in some areas. You can also cause work hardening or oil canning if you over heat the metal. You need a large compressor to do this right and a lot of media! Also you should be wearing a respirator!!! The dust can cause silicosis much less the nasty stuff you are blasting off in the paint
Um, do you actually have a filter on that respirator? And I'm not talking about that nose bra you have on. What brand/model respirator is that? You'll need a HEPA cartridge to go on it. Do you know how to test the seal?
  • Who's Online   2 Members, 0 Anonymous, 749 Guests (See full list)
