Posted March 29, 20178 yr comment_516713 see new link My guess is this is excessive.. Edited March 30, 20178 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/ Share on other sites More sharing options...
March 30, 20178 yr comment_516765 Something strange with that link. Takes me to videos of a Slot car Track. Edited March 30, 20178 yr by Chickenman Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/#findComment-516765 Share on other sites More sharing options...
March 30, 20178 yr Author comment_516787 Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/#findComment-516787 Share on other sites More sharing options...
March 30, 20178 yr comment_516791 Ok, now we see it Yes, very excessive. Pretty any visible movement is enough make significant looseness in the steering. Time for new rack bushings. Edited March 30, 20178 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/#findComment-516791 Share on other sites More sharing options...
March 30, 20178 yr Author comment_516792 they are on the way! One thing that is not obvious from the video is the car is on the ground, so there is load from the tires touching the ground. I assume some movement will take place, just not sure how much is too much. Edited March 30, 20178 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/#findComment-516792 Share on other sites More sharing options...
March 30, 20178 yr comment_516795 26 minutes ago, Dave WM said: they are on the way! One thing that is not obvious from the video is the car is on the ground, so there is load from the tires touching the ground. I assume some movement will take place, just not sure how much is too much. I've never really checked the rack with the car on the ground but it sure looks like way too much movement to me. Maybe someone installed 240Z bushings on your 280Z rack? Chuck Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/#findComment-516795 Share on other sites More sharing options...
March 30, 20178 yr Author comment_516799 it does not appear to have been wrenched on very much, could have 42 yr old rubber in there. So far every part I have looked at seems to be OE. I will make sure I get a video of the after to have something to compare to. Edited March 30, 20178 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/#findComment-516799 Share on other sites More sharing options...
March 31, 20178 yr comment_516858 Bushes are probably oil soaked and gone mushy. That's a technical Term LOL. Rack Bushings are one place that Poly Bushings are good. Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/#findComment-516858 Share on other sites More sharing options...
March 31, 20178 yr comment_516863 Ditto what the Chickenman wrote.... Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/#findComment-516863 Share on other sites More sharing options...
March 31, 20178 yr Author comment_516878 too late, got the rubber ones, should be here today. Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/#findComment-516878 Share on other sites More sharing options...
March 31, 20178 yr Author comment_516906 removed the old bushing since the UPS guy is supposed to be here soon, they don't look oil soaked or badly worn, will see how the new ones look. Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/#findComment-516906 Share on other sites More sharing options...
April 1, 20178 yr Author comment_516914 not going to bother with posting up new video, suffice it to say its the same with the new bushing as the old, which is not surprising given the old was not that bad. Perhaps the PU bushings have less give in them, but at least now you know what to expect with OE Nissan rubber. Link to comment https://www.classiczcars.com/forums/topic/57380-75-280z-steering-rack-movment/#findComment-516914 Share on other sites More sharing options...
