April 2, 20178 yr Author comment_517004 30 minutes ago, Zed Head said: People sometimes have to grind them off. That's my next plan of attack. Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517004 Share on other sites More sharing options...
April 2, 20178 yr comment_517014 After many removals of intakes at the JY if the shield bolts won't easily come off I leave it alone. Done take the chance of rounding them off. Remove the intake, get a good 6 point socket and they come right off. Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517014 Share on other sites More sharing options...
April 2, 20178 yr Author comment_517054 I managed to get the intake bolts off without any bolts or studs breaking, I also got all the exhaust bolts off except one. I am letting that one soak a bit more before I give it another go. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517054 Share on other sites More sharing options...
April 2, 20178 yr comment_517060 I've never had any patience until these cars, now life is better. Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517060 Share on other sites More sharing options...
April 2, 20178 yr comment_517064 If you manage to get it off with out snapping anything I may be get up the nerve to do this as well. I my case is so I can get the exhaust mani off so I can take it to the machine shop to fix the broken studs on the down pipe. Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517064 Share on other sites More sharing options...
April 2, 20178 yr Author comment_517066 I could cut the last bolt off, just carefully split it with a dremel. The heat shield was the biggest pain, I cut it off from the top with a dremel. I have replacement shields and and a new intake that was powder coated so I didn't care if I damaged the old one. I am putting a coated header on and really wonder if it necessary to put on the heat shield. What say y'all? Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517066 Share on other sites More sharing options...
April 2, 20178 yr comment_517068 5 minutes ago, Jaymanbikes said: I could cut the last bolt off, just carefully split it with a dremel. The heat shield was the biggest pain, I cut it off from the top with a dremel. I have replacement shields and and a new intake that was powder coated so I didn't care if I damaged the old one. I am putting a coated header on and really wonder if it necessary to put on the heat shield. What say y'all? Sent from my iPhone using Classic Zcar Club mobile I say yes. If it's a 280 the shield will need trimming, I'll post a picture of what I did in the morning. They keep the heat off your PCV hose and the master cylinders for the brakes. The coated header from MSA is what I have and they do a remarkable job dissipating heat, fantastic headers IMHO. If it's a 240 they keep the heat away from the carbs, percolation or hot restart prevention. Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517068 Share on other sites More sharing options...
April 2, 20178 yr Author comment_517071 It's a 280. The header I have is also from MSA, appreciate the info on how/what to trim. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517071 Share on other sites More sharing options...
April 3, 20178 yr comment_517115 Here's where I trimmed mine, the red circle. The other red circle is where my header touched the bellhousing. Had to grind that down a little to keep it from rattling. maybe your's won't hit there. I used tin snips to cut that with then went back and sanded the edges then VHT spray paint. Edited April 3, 20178 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517115 Share on other sites More sharing options...
April 3, 20178 yr Author comment_517117 Here's where I trimmed mine, the red circle. The other red circle is where my header touched the bellhousing. Had to grind that down a little to keep it from rattling. maybe your's won't hit there. I used tin snips to cut that with then went back and sanded the edges then VHT spray paint. Thanks for the info! I have a 3-2 header, doesn't look like it will contact the bell housing, we will see. I have a long road ahead of me before I get to that point. I am waiting for all the metal components to come back from plating. I am also considering at this point if I should just pull the motor so I can properly clean the engine compartment properly. The most intimidating thing to me is the AC system which works well. Not sure how I would go about discharging the system properly. It's has the old refrigerant which is really costly to replace as well. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517117 Share on other sites More sharing options...
April 3, 20178 yr Author comment_517118 Thanks for the info! I have a 3-2 header, doesn't look like it will contact the bell housing, we will see. I have a long road ahead of me before I get to that point. I am waiting for all the metal components to come back from plating. I am also considering at this point if I should just pull the motor so I can properly clean the engine compartment properly. The most intimidating thing to me is the AC system which works well. Not sure how I would go about discharging the system properly. It's has the old refrigerant which is really costly to replace as well. Sent from my iPhone using Classic Zcar Club mobile Here is where I am at now, lots of cleaning ahead. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517118 Share on other sites More sharing options...
April 3, 20178 yr comment_517120 55 minutes ago, Jaymanbikes said: I am also considering at this point if I should just pull the motor so I can properly clean the engine compartment properly. The most intimidating thing to me is the AC system which works well. Not sure how I would go about discharging the system properly. It's has the old refrigerant which is really costly to replace as well. Sent from my iPhone using Classic Zcar Club mobile I considered pulling mine also when I wanted to clean the engine bay. The cons outweighed the pros in my case except for the radiator, I did pull that and have it flushed, then I repainted it. I wound up doing one side at a time, unbolting everything and taping some hoses that couldn't get out of the way. Cleaned, degreased then repainted with colored matched enamel from the Automotive paint store as I went. Re-attached it all and was done (one side at a time, including the firewall. It was a little time consuming but I didn't have to remove the hood and wrestle anything else. If you are not painting, It should be even easier. That is also a good time repaint the block if you desire and steel wool the copper A/C lines when you are there. Before and after shots. Edited April 3, 20178 yr by gwri8 Added pictures Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=2#findComment-517120 Share on other sites More sharing options...
