April 3, 20178 yr comment_517122 1 hour ago, Jaymanbikes said: Here is where I am at now, lots of cleaning ahead. Sent from my iPhone using Classic Zcar Club mobile I love an use the blue painters tape too! So handy. Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-517122 Share on other sites More sharing options...
April 3, 20178 yr comment_517144 Why not just leave the AC connected and move it out of the way? I am not sure that's possible but it is what I have done in the past on other vehicles. Then pull the engine if needed... Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-517144 Share on other sites More sharing options...
April 3, 20178 yr Author comment_517148 Why not just leave the AC connected and move it out of the way? I am not sure that's possible but it is what I have done in the past on other vehicles. Then pull the engine if needed...I have some rust, surface primarily that is below where one of the copper lines transitions into the flex line. It is from an old brake fluid leak. My thinking was that if I yank the motor I would like to take care of that properly. I have decided against yanking the motor not enough time to take it that far. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-517148 Share on other sites More sharing options...
April 3, 20178 yr comment_517152 Yeah that would be best done next winter, enjoy it this summer. You may blow her up hearing that header screaming. Cheap walmart spray foam oven cleaner works good as does lacquer thinner cleaning the motor up in car. Simple Green with Scotch-Brite pads too. I bought a gallon of commercial de-greaser from a local chemical supply that worked great undiluted, make sure and wear some kind of rubber gloves though, if that stuff gets under your cuticles and finger nails it's like what I imagine bamboo felt like in the Vietnam warm. Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-517152 Share on other sites More sharing options...
April 3, 20178 yr Author comment_517159 Yeah that would be best done next winter, enjoy it this summer. You may blow her up hearing that header screaming. Cheap walmart spray foam oven cleaner works good as does lacquer thinner cleaning the motor up in car. Simple Green with Scotch-Brite pads too. I bought a gallon of commercial de-greaser from a local chemical supply that worked great undiluted, make sure and wear some kind of rubber gloves though, if that stuff gets under your cuticles and finger nails it's like what I imagine bamboo felt like in the Vietnam warm. Thanks for the tip. Here is a little mock up pic. Lots of work ahead.Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-517159 Share on other sites More sharing options...
April 4, 20178 yr comment_517160 Looks good! Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-517160 Share on other sites More sharing options...
April 4, 20178 yr comment_517191 Did you get that from RossiZ? I'm thinking you did but don't remember too good. It looks really cool beside that black valve cover. Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-517191 Share on other sites More sharing options...
April 4, 20178 yr Author comment_517192 Did you get that from RossiZ? I'm thinking you did but don't remember too good. It looks really cool beside that black valve cover.Yes I did, I had it powder coated and the EGR welded up. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-517192 Share on other sites More sharing options...
April 4, 20178 yr comment_517194 I thought something looked odd with the webbing on there. It's not an N-42 but a N-47 with the EGR welded up. Nice! Looking back maybe it is an N-42? Anyways it looks good. Edited April 4, 20178 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-517194 Share on other sites More sharing options...
April 4, 20178 yr Author comment_517195 I thought something looked odd with the webbing on there. It's not an N-42 but a N-47 with the EGR welded up. Nice! No webbing, that's the shield, look closely, it's a slightly different color. Not sure I like that though.Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-517195 Share on other sites More sharing options...
April 23, 20177 yr Author comment_518883 Finally I have it mostly put back together. I had all the metal parts Zinc plated which was a lot of work, fortunately I had two of everything so I was able to disassemble the car after I got the parts back. I didn't have to trim any of the heat shield with my header installed which was great. A few details and then the hood can go back on and off to the muffler shop. I purchased a 2.5" exhaust system from MSA awhile back and it hangs way low back near the diff. I suspect I will just have to have a custom piece welded up to get it right. Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-518883 Share on other sites More sharing options...
April 23, 20177 yr comment_518884 Great looking engine bay! You did a fine job with that. Those 2.5 exhaust can be a pain, taking it to a shop isn't too expensive. I paid $50 to have mine tucked up better. There's that cut out on the driver's side of the differential that it fits in but that wasn't made for such a larger pipe. I fought with mine then threw in the towel and the $50. Good investment for me. Good way to spend $50, I mean. That's just a couple of days of beer. Edited April 23, 20177 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/57405-remove-1977-280z-intake/?&page=3#findComment-518884 Share on other sites More sharing options...
