14 hours ago, Diseazd said:
Not sure about that Cliff....maybe someone else can answer that question. My guess is you need to match the larger caliper to a wider vented rotor. These calipers are huge, as is the rotor. It's a simple install.....Xmas is coming up....put these on your list and tape it to the fridge.
I use magnets instead of tape.  There's so many on there now I fear the fan is going to stop rotating. LOL
  • 1 month later...
What are your wheel specs? Square or staggered? Offset?
Not staggered.
16x8 +4 offset
Need to have coilovers in front with that set up and the 225/50's I have on.
Rear is okay with regular springs with a slight rub if I hit the right bump. If you zoom in you can see where it rubs.
