April 12, 20178 yr comment_517869 14 hours ago, Diseazd said: Not sure about that Cliff....maybe someone else can answer that question. My guess is you need to match the larger caliper to a wider vented rotor. These calipers are huge, as is the rotor. It's a simple install.....Xmas is coming up....put these on your list and tape it to the fridge. I use magnets instead of tape. There's so many on there now I fear the fan is going to stop rotating. Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-517869 Share on other sites More sharing options...
April 13, 20178 yr Author Popular Post comment_517948 All finished with the 73......new shocks, springs, ball joints, tie rod ends, wheel bearings, Wilwoods and bushings. I really like the way she sits and handles with the new Eibachs.....car drives like new. Now the car is as fun to stop as it is to go. If anyone needs help with any of the above improvements, feel free to ask. Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-517948 Share on other sites More sharing options...
May 15, 20177 yr comment_520999 Hey a silver Z car with Eibachs and panasports... Man that is a good look. Probably the best combination ever in the history of all things Z's. Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-520999 Share on other sites More sharing options...
May 16, 20177 yr comment_521073 What size are your wheels? I am planning on the same brake setup... Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-521073 Share on other sites More sharing options...
May 16, 20177 yr Author comment_521079 These are 15 inch wheels, but I have Wilwoods on 16 inch wheels too. Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-521079 Share on other sites More sharing options...
May 16, 20177 yr comment_521081 Interesting. I wasn't sure if the 15's would clear. Do they have an offset or are you running any spacers? Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-521081 Share on other sites More sharing options...
May 16, 20177 yr Author comment_521088 No spacers....not sure about offset.....wheels were on the car when I bought it. Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-521088 Share on other sites More sharing options...
May 16, 20177 yr comment_521091 Just finished up my front and rears 73Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-521091 Share on other sites More sharing options...
May 17, 20177 yr comment_521138 @Nick0227 where did you get the Mr. K sticker? Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-521138 Share on other sites More sharing options...
May 17, 20177 yr comment_521144 What are your wheel specs? Square or staggered? Offset? Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-521144 Share on other sites More sharing options...
May 17, 20177 yr comment_521152 [mention=31923]Nick0227[/mention] where did you get the Mr. K sticker?Geez some guy on a Z forum made a few. Sorry don't remember his name but if I come across it I'll definitely tag you. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-521152 Share on other sites More sharing options...
May 17, 20177 yr comment_521153 What are your wheel specs? Square or staggered? Offset? Not staggered. 16x8 +4 offset Need to have coilovers in front with that set up and the 225/50's I have on. Rear is okay with regular springs with a slight rub if I hit the right bump. If you zoom in you can see where it rubs. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57410-front-end-overhaul/?&page=4#findComment-521153 Share on other sites More sharing options...
