my 78 has the same problem. both doors. it's been that way since we bought the car 2 years ago. I haven't really done anything about it since it gets parked in the garage, and I live on an AF base where the neighborhoods are regularly patroled.
I understand this is a quite common occurence on the older Zs. my wife's 77 had the same problem.
eventually, I'm just gonna get new locks.
It could be something as simple as one of the rods on the latch lever binding. I can't remember exactly, but I believe there are plastic nuts on the ends of the vertical rods that adjust the lenght of the rods for both the outside lock and the outside door handle where it sits into the lever on the door patch.
You'll have to pull the door panel to access it, but it could be something that won't require you to buy any new parts......They are a bit tricky to access and adjust, but with a little tinkering you can adjust not only the outside door handle and lock, but if you look on the horizontal rod for the inside handle there is an adjustment there as well.
