April 12, 20177 yr comment_517839 IMO, Ignore the marks and rotate it until the tang is correct. Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-517839 Share on other sites More sharing options...
April 12, 20177 yr Author comment_517842 3 hours ago, Zpat said: Sorry to be so late to this party but this thread is very relevant as I recently pulled my distributor on my '72 240 and my oil pump shafts tang is in the exact 1:00 position as your original picture even though by all measurements I am at TDC (pistons at top, cam gear v notch lining up with thrust plate dash, cam lobes where they should be etc). I believe the gear oil pump shaft moved/slipped when I pulled my distributer. Could you give a quick outline of how you moved the tang back to the 11:30 position? Sent from my SAMSUNG-SM-G900A using Classic Zcar Club mobile i finally got it where it is supposed to be, and it fired right up. line up the marks as shown, turn the shaft a little clockwise?, then push it up in there. tighten one bolt finger tight and the take a look. it may take a few tries (you will be an expert shortly) but it will eventually go. very aggravating Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-517842 Share on other sites More sharing options...
April 12, 20177 yr comment_517843 Thanks all, sounds like just twist, turn, shove. If not correct, repeat until correct. Just wanted some direction as a chill went down my back when I saw sweatybettys first picture when the tang was at 1:00, identical to mine and hearing his earlier problems. I'm sure I will come back to the well if I have any problems. Happy motoring...Sent from my SAMSUNG-SM-G900A using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-517843 Share on other sites More sharing options...
April 12, 20177 yr Author comment_517844 i have narrowed my problem down to 2 cylinders mis-firing which Zed led me to. Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-517844 Share on other sites More sharing options...
April 16, 20177 yr Author comment_518203 the car is running now. i have put my timing light on every wire, and the light will work on all but # 1 & 3. i have switched wires around but no difference. new cap and rotor, no difference. i tried pulling #1 wire off the plug, and get a great spark to ground. im going to try new plugs tomorrow, any recommendations? thanks all sb Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-518203 Share on other sites More sharing options...
April 16, 20177 yr comment_518204 Seems like it would be the distributor that has a problem. Wobble, bad points gap w worn cam? Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-518204 Share on other sites More sharing options...
April 16, 20177 yr Author comment_518207 54 minutes ago, 240260280 said: Seems like it would be the distributor that has a problem. Wobble, bad points gap w worn cam? the distributor feels tight, no wobble that i can feel. im running pertronix ignition, so no points. i have turned the magnets several times with no difference Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-518207 Share on other sites More sharing options...
April 16, 20177 yr comment_518209 I've seen it proposed but haven't actually seen it - bad grounding of the spark plug body and threads to the head. Several ways to test it or fix it, from vigorous cleaning of the threads to running a dedicated ground wire from the plug body to ground, or jamming a screwdriver between the plug and head. You get the idea. Seems far-fetched but fits the symptoms. Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-518209 Share on other sites More sharing options...
April 16, 20177 yr Author comment_518213 im thinking along those lines also. ill try the ground wire. Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-518213 Share on other sites More sharing options...
April 16, 20177 yr comment_518220 Maybe electronics are set for 4 cylinder rather than 6? Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-518220 Share on other sites More sharing options...
April 17, 20177 yr Author comment_518237 5 hours ago, 240260280 said: Maybe electronics are set for 4 cylinder rather than 6? there is nothing to set. pertronix ignition and factory tach. Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-518237 Share on other sites More sharing options...
April 17, 20177 yr comment_518246 12 hours ago, Zed Head said: Seems far-fetched but fits the symptoms. Bad ground occurred to me too. It does seem far fetched but who knows... Wires, cap & rotor don't change it, so: plugs or distributor/pertronix Link to comment https://www.classiczcars.com/forums/topic/57439-at-wits-end/?&page=6#findComment-518246 Share on other sites More sharing options...
