40MM SK OER triple carbs. The carbs come with new master rebuild kits from OER and the following new weber style jets etc. F11 Emulsion tubes x 3. Main Jets x 6 of each 120, 122, 125, and 130. 35 pump bleed x 3. Air jet 200 x 6, 45F9 idle X 6. It has new OER 45 pump nozzles, used 75 pump nozzles and non numbered pump bleeds in there currently. They come with a set of new baking isolators and gaskets. They do not come with the fuel fittings. Asking 1000 OBO
Edited by nismospek
https://www.classiczcars.com/forums/topic/57502-sk-oer-triple-carbs/
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
Guest
Reply to this topic...
