N27 needle equivalent?
Boomguy
10 hours ago, SteveJ said:
That table is needles designed for the .090 nozzle. Anything in that list will be way too rich to run in the .100 nozzle.
Maybe one could switch over to a .090 nozzle/needle pair and find something that might work?
I think I'll stick to the .100 jet combo. :)
I have scoured all the tables on su needles looking for something comparable and honestly there isn't much. Hitachi really had their own ideas of slope for the needles when they came up with this.
N47 Alternatives according to profiles:
KI will give richer mid band: http://sucarb.co.uk/catalogsearch/result/?q=KI
SM will give richer high rpm band
SA and SH will give leaner mid-high band
KH will give richer low-mid and leaner mid-high band
SI will giver richer low-mid and richer mid band
SP will give leaner mid and high band band
  • 9 months later...
I am using sm needles on my 3 screws su carbs with a modified  2.6 liter engine and  schneider 274f and its impossible to have a smooth idle with them. I guess they are still too rich at idle. So rich plugs start to foul and engine tends to stall on traffic jams. Using atf as damper oil.
Edited by jalexquijano
  • Who's Online   2 Members, 0 Anonymous, 693 Guests (See full list)
