Posted April 22, 20178 yr comment_518767 I ordered the wrong distributor cap! the one I have now is for a 1977 280z and the distributor cap needed is for a 1980 280zx distributor. the 280z fits fine tight no wobble and ignition timing has not changed . does anybody know the difference between the 2 cap as they have different part #s. was ordering plugs for the 1977 and did not change the year for the distributor cap and rotor. Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/ Share on other sites More sharing options...
April 22, 20178 yr comment_518775 Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/#findComment-518775 Share on other sites More sharing options...
April 22, 20178 yr comment_518776 The ZX cap is bigger than a Z's. Also the spark plug gap is wider too. Edited April 22, 20178 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/#findComment-518776 Share on other sites More sharing options...
April 22, 20178 yr comment_518778 What I meant to post before my phone nuked itself was the question of the built in resistor plugs optional for ZX's. Not sure if the S30 runs them and if there's any differences with the cap because of it. Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/#findComment-518778 Share on other sites More sharing options...
April 22, 20178 yr comment_518793 I personally run the ngk bp6es copper plugs like the originals, just widen the gap. Its something like .38 to .44 for the ZX. They're not stocking them anymore and reccomend a hotter bp5es I think. I read it's a result of the new blend of gasoline & ethanol. Don't know for sure though, read on the www.com. Ngk has a neat plug finder on there web page, try that. Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/#findComment-518793 Share on other sites More sharing options...
April 22, 20178 yr comment_518795 How does the inside of the cap look? If it's clean and the electrodes aren't corroded it's probably fine for a few more miles. Just realized that I've been running resistor plugs with resistor wires. Not sure what the effects are, I haven't noticed any. Research needed. But it's a reason to mess around a little more. The plugs are new, but the wires old. But I don't think you can get non-resistor wires any more. Dilemma. Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/#findComment-518795 Share on other sites More sharing options...
April 22, 20178 yr Author comment_518799 I made the mistake and ordered the 1977 280z cap and rotor instead of the 1980 zx cap and rotor from rock auto. the cap and rotor fits tight no play seems to fit like it belongs there and car runs great just seems fine. I would just do not know what the difference is being beck arnley has a different part # for the 1980 zx dissy Edited April 22, 20178 yr by kully 560 Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/#findComment-518799 Share on other sites More sharing options...
April 22, 20178 yr comment_518800 Did you post this same question on Hybridz? Are you sure the distributors are different? You're posting years but not mentioning the matchbox ignition module. Does one have the E12-80 and one not? Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/#findComment-518800 Share on other sites More sharing options...
April 22, 20178 yr comment_518802 My '77 cap is way smaller than my zx cap. Are you sure you have a zx distributor? Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/#findComment-518802 Share on other sites More sharing options...
April 22, 20178 yr comment_518804 The zx cap is taller. IIRC Edited April 22, 20178 yr by rcb280z Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/#findComment-518804 Share on other sites More sharing options...
April 22, 20178 yr Author comment_518806 yes it is a zx distributor #d6k8-22 has very high vacuum advance that's why I run it with vacuum advance plugged up and have my timing advanced to 36 degrees all in! Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/#findComment-518806 Share on other sites More sharing options...
April 22, 20178 yr comment_518807 Not trying to be d*** but my '77 cap will not fit my ZX distributor. It's a good bit shorter and I'm unable to to clip the side hold downs on. But if you have the '77 cap and rotor I guess they will work together, if your car runs, I can't argue with that. I apologize for doubting you. Cliff The ZX has the blue plug wires attached in these photos Link to comment https://www.classiczcars.com/forums/topic/57550-distributor-cap-fitment/#findComment-518807 Share on other sites More sharing options...
