Posted April 27, 20178 yr comment_519287 Last free day before I start a rally next week and I realized that my spare tire won't fit my Toyota brake setup on my 240z! Need to get out to a pick and pull ASAP to grab a compact spare or .... to fit in my wheel well, who knows what Works? My wheels are 15" rikens with 205/50/15s. Brakes are Toyota 4 puck s12w and rears are 300z disk setup. Any input greatly appreciated and I will keep searching the archives! Chris Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/ Share on other sites More sharing options...
April 27, 20178 yr comment_519288 Here's a single 15x7 Rota for $35. https://baltimore.craigslist.org/wto/6105291236.html Chuck Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/#findComment-519288 Share on other sites More sharing options...
April 27, 20178 yr comment_519289 Nevermind. You're looking for just a tire. Chuck Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/#findComment-519289 Share on other sites More sharing options...
April 27, 20178 yr Author comment_519290 Thanks for looking Chuck, I am just looking for a model of car that might have a compact spare that would fit. I have read that a 93 Hyundai elantra will work but the center hole isn't big enough for our front hub. Chris Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/#findComment-519290 Share on other sites More sharing options...
April 27, 20178 yr comment_519291 What year is your car? The Z's used a full size tire up to 1977. And you just mentioned that the hub size is your problem but the hub fit shouldn't have anything to do with the brake calipers. Not really clear what's "not fitting". Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/#findComment-519291 Share on other sites More sharing options...
April 27, 20178 yr Author comment_519292 Apologies, I need a Spare Tire (wheel, donut, compact spare) for a 1970 240z that will clear upgraded disk brakes. I need to go to a car wrecking yard today to get something that fits because this is my last day to work on the car. I was looking for someone who has found a Spare that will address my issue. I mentioned the Elantra as I had read that it may work, maybe someone can confirm that? Chris Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/#findComment-519292 Share on other sites More sharing options...
April 27, 20178 yr comment_519295 If you provided a measurement, it might help your cause. Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/#findComment-519295 Share on other sites More sharing options...
April 27, 20178 yr comment_519296 I have a first generation Nissan Altima donut that works well. Its thin enough so it should clear the bigger brakes. Here's an example: http://www.ebay.com/itm/93-97-Nissan-Altima-OEM-temporary-spare-rim-tire-donut-wheel-125-70-15-/192039515577?fits=Model%3AAltima&hash=item2cb67275b9:g:WlgAAOSwEzxYPHzU&vxp=mtr Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/#findComment-519296 Share on other sites More sharing options...
April 27, 20178 yr Author comment_519297 Thanks Jarvo2! That's the info that will work well! Being on a 15" rim should help clear the brakes and it's probably only about 25" overall diameter so it should tuck into the spare tire well nicely! Chris Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/#findComment-519297 Share on other sites More sharing options...
April 27, 20178 yr comment_519298 Three shoulds and a probably. Good luck. Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/#findComment-519298 Share on other sites More sharing options...
April 27, 20178 yr comment_519299 I'm not using my Altima spare & happy to let it go for $50, located in Chicago for anyone local. Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/#findComment-519299 Share on other sites More sharing options...
April 28, 20178 yr comment_519344 Don't forget that the rear wheels/tires can be spares for flat up front if you put the small holed spare on the rear and rotate a good rear to replace a flat up front. Had that some issue with a set of alloys many years ago, Just have to jack the car twice instead of once. Dennis Link to comment https://www.classiczcars.com/forums/topic/57586-need-a-spare-tire-asap/#findComment-519344 Share on other sites More sharing options...
