Posted May 5, 20178 yr comment_519929 How does a search for "tie rod" in the suspension and steering section turn up 0 hits? The server may be having a bad day. My tie rods and other components need replacing but I can NOT back off the locking nut of the outer tie rod end on the driver side. I snapped a wrench on this thing and this after hours of soaking with liquid wrench. Is it possible that the driver side is reverse threaded? Thanks, guys. Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/ Share on other sites More sharing options...
May 5, 20178 yr Author comment_519931 Sorry, guys. The search didn't work but a simple scroll down the page did. I see that it is reverse threaded. Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/#findComment-519931 Share on other sites More sharing options...
May 5, 20178 yr comment_519937 quite a few older vehicles have left hand threads on the left side. not so much anymore Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/#findComment-519937 Share on other sites More sharing options...
May 5, 20178 yr comment_519938 Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/#findComment-519938 Share on other sites More sharing options...
May 5, 20178 yr comment_519952 On 5/5/2017 at 12:13 AM, mentalite said: Sorry, guys. The search didn't work but a simple scroll down the page did. I see that it is reverse threaded. I try to remember that the right is "right" and the left is "wrong". It's like bike pedals and crank bearings. The left side lug nuts on my Road Runner and AAR cuda are LH thread. The other day I struggled for a few seconds to remove a lug nut. Chuck Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/#findComment-519952 Share on other sites More sharing options...
May 5, 20178 yr Author comment_519959 On 5/5/2017 at 1:33 AM, Captain Obvious said: A quality Far Side reference is always welcomed. Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/#findComment-519959 Share on other sites More sharing options...
May 5, 20178 yr Author comment_519960 On 5/5/2017 at 10:10 AM, cbuczesk said: I try to remember that the right is "right" and the left is "wrong". It's like bike pedals and crank bearings. The left side lug nuts on my Road Runner and AAR cuda are LH thread. The other day I struggled for a few seconds to remove a lug nut. Chuck That's why this somewhat puzzles me, Chuck. Reversing the threading counter to the spin as in the left side pedal spindle makes sense. I see no reason for it here. Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/#findComment-519960 Share on other sites More sharing options...
May 5, 20178 yr comment_519966 On 5/5/2017 at 12:26 PM, mentalite said: A quality Far Side reference is always welcomed. Always! So I wasn't there when they designed the thing, but my read on the thread directions is just to make it more "intuitive" to set the alignment. I don't think it's an accidental loosening thing like they sometimes do with lug nuts. Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/#findComment-519966 Share on other sites More sharing options...
May 5, 20178 yr comment_519981 When adjusting toe you can do both sides at the same time, same direction, same amount, without losing the centering of the wheel. Addendum to comment above. Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/#findComment-519981 Share on other sites More sharing options...
May 5, 20178 yr comment_519996 Marking them also helps for the next time you're under the car.... Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/#findComment-519996 Share on other sites More sharing options...
October 5, 20177 yr comment_531750 Stock driver's side is reverse threaded. Nissan doesn't make left side parts any more. I am currently looking into where to get inner and outer tie rod ends and the only place I'm seeing the inners is Z Car Depot, and I have no idea who makes them. I do know they aren't OEM. If anyone has another source, please let me know. Another option is getting a remanufactured steering rack, but I don't know if those would be reverse threaded on the driver's side. I'll post when I have more information. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/#findComment-531750 Share on other sites More sharing options...
October 5, 20177 yr comment_531752 I avoided this issue completely and ordered the complete inner and outer kit from Techno Toy Tuning. Both R/R Link to comment https://www.classiczcars.com/forums/topic/57642-drivers-side-tie-rod/#findComment-531752 Share on other sites More sharing options...
