Posted May 15, 20177 yr comment_520992 Any easy method of checking the fuel level in the float bowls of 3 screws round top SU CARBS? My car runs great at high speed but at idle it does not perform correctly. Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/ Share on other sites More sharing options...
May 15, 20177 yr comment_520994 This is one of the best ones I've seen!https://zcardepot.com/tools/carburetor-float-sync-tool-su-240z.html Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/#findComment-520994 Share on other sites More sharing options...
May 15, 20177 yr Author comment_521017 how do you use it? Im calling Bruce at Ztherapy to make an order but cant find him! Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/#findComment-521017 Share on other sites More sharing options...
May 15, 20177 yr comment_521024 On your three screw carbs, there should be a float bowl drain plug on the side of the float bowls. The "float sync. tools" replace the drain plugs with the clear tube oriented up. The fuel height in the tube is the same as the fuel height in the bowl. same as if there was a window in the side of the bowl. Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/#findComment-521024 Share on other sites More sharing options...
May 16, 20177 yr Author comment_521035 just got in touch with Bruce and order the damn tool! I dont want to mess with anything inside! Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/#findComment-521035 Share on other sites More sharing options...
May 16, 20177 yr comment_521037 Bruce and Z Therapy don't have them. I'm the manufacturer and sell them on Ebay for $69.95. I had the same issue as many others so I designed this product. The nice thing about them is that you can check fuel levels with the running or not Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/#findComment-521037 Share on other sites More sharing options...
May 16, 20177 yr comment_521055 Great looking gadget Randalla. Now we just need better bowl gaskets. The cork ones really suck. Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/#findComment-521055 Share on other sites More sharing options...
May 16, 20177 yr Author comment_521074 5 hours ago, Randalla said: Bruce and Z Therapy don't have them. I'm the manufacturer and sell them on Ebay for $69.95. I had the same issue as many others so I designed this product. The nice thing about them is that you can check fuel levels with the running or not Well i thought that since ztherapy announced it in their site they could sell me one. Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/#findComment-521074 Share on other sites More sharing options...
May 20, 20177 yr comment_521376 Check the post above showing my units. The ad is for Z Car Depot, not Z Therapy. Ryan at Z Car Depot is a customer of mine and I believe he may still have a few units left. Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/#findComment-521376 Share on other sites More sharing options...
May 20, 20177 yr comment_521392 7 hours ago, Randalla said: Check the post above showing my units. The ad is for Z Car Depot, not Z Therapy. Ryan at Z Car Depot is a customer of mine and I believe he may still have a few units left. Just ordered one from ebay. Looks like a great tool. Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/#findComment-521392 Share on other sites More sharing options...
May 21, 20177 yr Author comment_521446 how does it work? Just remove the bolt at the front of the float bowl??? Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/#findComment-521446 Share on other sites More sharing options...
May 21, 20177 yr comment_521454 7 hours ago, jalexquijano said: how does it work? Just remove the bolt at the front of the float bowl??? I don't want to speak for Randy, but looks relatively simple. It screws in with banjo bolt to the drain port on the float bowl and with the top of the tube open the fuel will level out in the tube at the float bowl level. This give you accurate comparison to balance out the two float bowls for even fuel flow to front and rear carbs thus front and rear cylinders. I wish I had access to this product years ago! Can't wait to get mine and see where I am at on my adjustments. This definitely beats blow into the inlet and raise the float until it stops the air flow method of setting the levels! Link to comment https://www.classiczcars.com/forums/topic/57733-checking-correct-fuel-level-at-round-top-3-screw-su-carbs-float-bowls/#findComment-521454 Share on other sites More sharing options...
