Posted May 15, 20177 yr comment_521032 I can't get carbs to idle down. They either rev high or when they calm down, it stalls. Any help until I can look closer at them? Thank you. Link to comment https://www.classiczcars.com/forums/topic/57738-quick-help-with-triple-mikunis/ Share on other sites More sharing options...
May 16, 20177 yr comment_521033 Sounds like a vacuum leak . Did a plug of some kind pop off?Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57738-quick-help-with-triple-mikunis/#findComment-521033 Share on other sites More sharing options...
May 16, 20177 yr comment_521034 Make sure linkage isn't bindingSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57738-quick-help-with-triple-mikunis/#findComment-521034 Share on other sites More sharing options...
May 16, 20177 yr comment_521064 Depending on the linkage a little grease might be needed in the cups/ball connectors. Could be worse and have it stay wide open... Link to comment https://www.classiczcars.com/forums/topic/57738-quick-help-with-triple-mikunis/#findComment-521064 Share on other sites More sharing options...
May 16, 20177 yr comment_521070 A video of the problem would help a lot. Â It's useful to see whats happening. Â Link to comment https://www.classiczcars.com/forums/topic/57738-quick-help-with-triple-mikunis/#findComment-521070 Share on other sites More sharing options...
May 17, 20177 yr comment_521194 I would disconnect the linkage from the carbs and see how it acts.Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57738-quick-help-with-triple-mikunis/#findComment-521194 Share on other sites More sharing options...
May 17, 20177 yr comment_521197 Absolutely begin with all three carbs independant linkage wise. Get each one flowing the same as you set the idles amoungst the three until the car idles well.  Make sure the idle mix screws are all the same turns out (1, 1.5, not past three or you have other issues...) as a starting point. THEN hook up the linkage (should not cause ANY throttle change from base case) and get it idling again. Link to comment https://www.classiczcars.com/forums/topic/57738-quick-help-with-triple-mikunis/#findComment-521197 Share on other sites More sharing options...
May 27, 20177 yr comment_521865 Are you using return springs? Link to comment https://www.classiczcars.com/forums/topic/57738-quick-help-with-triple-mikunis/#findComment-521865 Share on other sites More sharing options...
