Posted May 29, 20177 yr comment_521942 I rebuilt my entire suspension about 8 months ago, I used the prothane bushings throughout. At the same time I replaced my struts with KYB's and installed lowering springs. The car has a slight clunk in the rear when I hit small sharpe bumps, a good example would be small traffic markers. I have double checked every nut and bolt and they are torqued to spec. The lowering springs do not seat into the perch's until the car is loaded and I am wondering if that might be the source of the clunk. I did zip tie the springs to the lower perchs but that didn't help. The cars suspension was original and had a lot of noises to start with so I'm not certain if this was there to begin with or not. Thanks to all! Jay Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/ Share on other sites More sharing options...
May 29, 20177 yr comment_521951 Did you replace the differential mount? Those cause a lot of the thunks on Zs. Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/#findComment-521951 Share on other sites More sharing options...
May 29, 20177 yr Author comment_521952 Yep, I replaced that as well. It sounds sort of like what you would think a loose strut would sound like. Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/#findComment-521952 Share on other sites More sharing options...
May 29, 20177 yr comment_521960 Is the gland nut pressing on the KYB shock body, or is it bottomed out on the external strut housing? Sometimes a washer on top of the shock is necessary to get proper clamping. Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/#findComment-521960 Share on other sites More sharing options...
May 29, 20177 yr Author comment_521964 Thanks, will double check that next time I have it on the liftSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/#findComment-521964 Share on other sites More sharing options...
May 29, 20177 yr comment_521981 After I rebuilt the rear suspension on my 280 I also had a clunk when I hit small bumps. Solved by greasing the 2 blocks holding the rear sway bar to the body. I think they were binding until they let go over a bump and then CLUNK. Maybe an easy fix? Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/#findComment-521981 Share on other sites More sharing options...
May 30, 20177 yr Author comment_521988 On 5/29/2017 at 11:17 PM, jbond said: After I rebuilt the rear suspension on my 280 I also had a clunk when I hit small bumps. Solved by greasing the 2 blocks holding the rear sway bar to the body. I think they were binding until they let go over a bump and then CLUNK. Maybe an easy fix? That's an easy try! Thanks! Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/#findComment-521988 Share on other sites More sharing options...
June 23, 20177 yr Author comment_523798 On 5/29/2017 at 5:23 PM, Zed Head said: Is the gland nut pressing on the KYB shock body, or is it bottomed out on the external strut housing? Sometimes a washer on top of the shock is necessary to get proper clamping. So I finally got around to disassembling one of my rear struts. The gland nut hits the top of the strut cartridge and thus does not allow the gland nut to bottom out. Also, inside the gland nut is a sleeve that is removable and pictured. This is the gland nut that came with the KYB struts, the instructions that came with the struts was very generic and zero help. Thanks for any suggestions. I am hoping that this might be the root cause of my suspension noise when going over sharp bumps. Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/#findComment-523798 Share on other sites More sharing options...
June 23, 20177 yr comment_523807 On 6/23/2017 at 9:16 PM, Jaymanbikes said: The gland nut hits the top of the strut cartridge and thus does not allow the gland nut to bottom out. Also, inside the gland nut is a sleeve that is removable and pictured. All of that is correct. The nut is supposed to clamp the insert in to the strut tube. The sleeve keeps the insert centered. Your gland nut does look a little bit deep though. When you tighten it down are you sure that it is actually clamping the top of the insert? It might be bottoming out on the internal threads. Tighten it down with the shock/insert inside then grab the shaft of the shock and see if it can be moved side to side or up and down. You can put a washer on top to get more clamping if it's bottoming out on the internal threads. Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/#findComment-523807 Share on other sites More sharing options...
June 24, 20177 yr Author comment_523826 On 6/23/2017 at 10:43 PM, Zed Head said: All of that is correct. The nut is supposed to clamp the insert in to the strut tube. The sleeve keeps the insert centered. Your gland nut does look a little bit deep though. When you tighten it down are you sure that it is actually clamping the top of the insert? It might be bottoming out on the internal threads. Tighten it down with the shock/insert inside then grab the shaft of the shock and see if it can be moved side to side or up and down. You can put a washer on top to get more clamping if it's bottoming out on the internal threads. OK, looks like I had everything correct on the struts. I reassembled everything, I also installed a set of the Whiteline Mustache Bar bushings which are supposed to be a lower durometer than the standard Poly bushings. Well, I must say the bushings made a huge difference, reduced road noise and gear whine significantly. I wasn't really expecting that big a difference, they feel just slightly softer to the touch. Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/#findComment-523826 Share on other sites More sharing options...
June 24, 20177 yr comment_523838 Did the clunk go away? The bag looks nice but are the bushings black? Are they shiny or dull? How do they feel on your face? Soft and smooth? I digress... Good info on the results, you had the hard polyurethane before? Do you know the brand? Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/#findComment-523838 Share on other sites More sharing options...
June 24, 20177 yr Author comment_523845 On 6/24/2017 at 4:22 AM, Zed Head said: Did the clunk go away? The bag looks nice but are the bushings black? Are they shiny or dull? How do they feel on your face? Soft and smooth? I digress... Good info on the results, you had the hard polyurethane before? Do you know the brand? The clunk is gone...The new bushings are black and shiny, also notice the taper on the end of the bushing. See the first pic. The green stuff is a marine grease I used to keep the washer in place as I installed the bar. The bushings were extremely tight, I had to shave a small amount of material to get them pressed into the bar. The old ones are Prothane, see second pic. I purchased them in a kit from Zcardepot. they are dullish and and have no taper. Link to comment https://www.classiczcars.com/forums/topic/57822-280z-rear-suspension-clunk/#findComment-523845 Share on other sites More sharing options...
