Posted June 22, 20177 yr comment_523706 My new toy tool arrived yesterday and with the weather being crud I just thought I would try it. So, what I got was an Astro DS2000 door skin removal tool. Took 30 minutes max to strip the door skin off the 240z door with the flange fold still attached. Can't wait for the DS1000 door skin crimper to show to reinstall the skin once done. Plan is to bead blast the inside of door frame and back side of the door skin. Seal-paint and reinstall. Hopefully good for another 40 years. uploadfromtaptalk1498172594724uploadfromtaptalk1498172701625 Sent from my ASUS Transformer Pad TF700T using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/ Share on other sites More sharing options...
June 22, 20177 yr Author comment_523708 Odd, I tried uploading the pictures but crashed. So, trying again through the laptop. Like I mentioned this thing worked really slick. Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/#findComment-523708 Share on other sites More sharing options...
June 23, 20177 yr comment_523730 So it opens the crimp edge? Most of the ones I've seen cut the flange off, but since we don't have a good source for door skins that's really not desirable Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/#findComment-523730 Share on other sites More sharing options...
June 23, 20177 yr comment_523803 Looks pretty slick. Does bead blasting generate much heat? I ask because sand does and it will reshape the door skin. Good tool though. Local big box hardware store or special order? Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/#findComment-523803 Share on other sites More sharing options...
June 25, 20177 yr Author comment_523946 Order the tool from Astro (company who makes it). Yes, the tool fold the lip of the door skin up and back. Panel just slips off. As for blasting, if you sit in one spot you canwarp the panel. I move from one side to the other. Eventually I get the whole thing done. ILike today, took the cross bar out of the door and blasted both the door frame and door skin. Ready to rust seal with KBS rust blast.Sent from my SM-G930V using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/#findComment-523946 Share on other sites More sharing options...
June 25, 20177 yr comment_523961 Thats awesome, may have to look into it. Would it work on the hood? Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/#findComment-523961 Share on other sites More sharing options...
June 25, 20177 yr Author comment_523969 If you can get the lip to lift with their skin removal pliers, I would say yes.Sent from my SM-G930V using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/#findComment-523969 Share on other sites More sharing options...
July 29, 20177 yr Author comment_526892 Finally got some time this evening after work, doing dishes, and mowing the lawn to work on the passenger door. I am trying out the KBS products (rust seal/preventative). Earlier I had removed the door skin. Tonight I applied their Rust Blast (etching and a zinc coating). This evening I sprayed their Rust seal urethane paint. Debating whether I will either use Lizzard skin or mats yet. Plan to do that before reassembling the door.Hope to get the door reassembled this weekend, maybe. Sent from my SM-G930V using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/#findComment-526892 Share on other sites More sharing options...
August 5, 20177 yr Author comment_527459 Didn't work on the door today but did work on stripping paint off the body today. Decided to try an old bodyman trick stripping paint.Was taught (ok, was told) to put the chemical stripper on the surface and wrap it plastic wrap to trap the chem vapor on the paint and to keep it from drying out on you. You use a lot less chemical too.Sent from my SM-G930V using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/#findComment-527459 Share on other sites More sharing options...
August 5, 20177 yr comment_527462 Nice job! Looks like it worked well. I've only chemically stripped one car and found it had been painted four different colors over the years - a messy job. I did mine outside on the driveway. Dennis Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/#findComment-527462 Share on other sites More sharing options...
August 6, 20177 yr Author comment_527481 Thanks Dennis. This car 2 layers. The 2nd car is 4 layers plus the primer. One car at time, right.Enjoy the weekend.WayneSent from my SM-G930V using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/#findComment-527481 Share on other sites More sharing options...
August 6, 20177 yr comment_527499 The guy who just did the paint on my car told me if I was going to chemical strip it that I better get every last bit of paint, primer and filler off the metal then clean and sand or that stripper would find it's way into the new paint job and screw it up. Your car looks like it is in pretty good shape, even has original wheel well lips. Link to comment https://www.classiczcars.com/forums/topic/57967-new-tool-toy/#findComment-527499 Share on other sites More sharing options...
