WOW man, that's a big ask. If someone has one they probably need it for a car they have. Contact Atlanta Z in Norcross Georgia. They may be able to help you. Do you mind if I ask what happened to the one the car came WITH? Just curious!
I don't have one I can spare, but I can give you pictures and dimensions if that helps.
If you are considering using it instead of the later style, the mounting method is so different it would be easier to make yourself a custom one that works with your exhaust. Then you can taylor it to be exactly what you need.
ZKars thanks. I actually have one but didn't want to remove it while I play around with my ideas about what might work.
Don's iPhone using Classic Zcar Club mobile
