Posted June 26, 20177 yr comment_524094 Hey All, jst a question about wiring in the zx alternator upgrade. Have installed the alternator and adaptor from Dave, the car is charging but the Amp gauge fluctuates wildly when car is running. Does this look like the correct wiring for the alternator. Car is a 12/70 240Z. Going out to change the oil, thanks in advance for any input! Mark Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/ Share on other sites More sharing options...
June 26, 20177 yr comment_524095 I would spin that batt connection (A) around 180degrees, it looks dangerously close to grounding out to the center of the alt. Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/#findComment-524095 Share on other sites More sharing options...
June 26, 20177 yr Author comment_524100 Thanks Dave, will do.otherwise looks correct? Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/#findComment-524100 Share on other sites More sharing options...
June 26, 20177 yr Author comment_524101 Woops! posted the wrong picture! Standby! Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/#findComment-524101 Share on other sites More sharing options...
June 26, 20177 yr comment_524102 Did this alternator come with an internal or external voltage regulator? The conversion is for the purpose of eliminating the external regulator. So if you haven't disconnected the external regulator it may cause an erratic response inside the car on the guage. Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/#findComment-524102 Share on other sites More sharing options...
June 26, 20177 yr Author comment_524103 Sorry, here is the correct photo! I know one wire is not secured with a nut . Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/#findComment-524103 Share on other sites More sharing options...
June 26, 20177 yr Author comment_524105 Yes the ZX adapter plug is installed and external regulator removed Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/#findComment-524105 Share on other sites More sharing options...
June 26, 20177 yr comment_524107 Ok. Test it Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/#findComment-524107 Share on other sites More sharing options...
June 26, 20177 yr Author comment_524108 This is how I've had it wired . The gauge fluctuates. I am tightening the belt as it seems too loose. Is there another way to wire this? Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/#findComment-524108 Share on other sites More sharing options...
June 26, 20177 yr Author comment_524112 Well..... i got my son to tighten the bolt on the alternator while i pried on it to hold it in position. That seems to have done it! the gauge is behaving normally now, apparently a slipping belt will cause the gauge to fluctuate? Seems to idle better too! Going for a test drive! Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/#findComment-524112 Share on other sites More sharing options...
June 26, 20177 yr Author comment_524120 Spoke to soon, test drive revealed the gauge behaving normally for a while, then fluctuating wildly again.I'm thinking that if the belt has been slipping for a while, it is worn and now slipping all the time. Does anyone agree that a slipping belt will cause fluctuations in the Amp gauge? Time for the MSA alt. adj arm and a new belt I think. Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/#findComment-524120 Share on other sites More sharing options...
June 27, 20177 yr comment_524131 Did you have any issues with the ammeter before you made the swap? I'm leaning towards a loose ground somewhere but if you didn't touch anything else all you can do is back track or shoot ZsOndabrain a quick inquiry. You should be able to sort it. Check in the trouble shooting section of the Haynes Manual also to see what would cause an erratic guage. It will probably point you right the issue. Link to comment https://www.classiczcars.com/forums/topic/57994-zx-alternator-upgrade/#findComment-524131 Share on other sites More sharing options...
