Posted July 19, 20177 yr comment_526104 I've read conflicting information on a few boards about the differences between the modern formula for safari gold and how well it matches. Can anyone share specific experiences? It's a full reliant so color match isn't the issue, I only want to be in body shop jail once. Thabks Link to comment https://www.classiczcars.com/forums/topic/58157-modern-formula-for-safari-gold/ Share on other sites More sharing options...
November 15, 20177 yr Author comment_534961 Still in body shop jail, but have a test spray. bump for any info, this doesn’t look right Link to comment https://www.classiczcars.com/forums/topic/58157-modern-formula-for-safari-gold/#findComment-534961 Share on other sites More sharing options...
November 15, 20177 yr comment_534975 Are they using ppg? Link to comment https://www.classiczcars.com/forums/topic/58157-modern-formula-for-safari-gold/#findComment-534975 Share on other sites More sharing options...
November 15, 20177 yr Author comment_534976 2 minutes ago, duffymahoney said: Are they using ppg? 2 minutes ago, duffymahoney said: Are they using ppg? Yeah, shopline Link to comment https://www.classiczcars.com/forums/topic/58157-modern-formula-for-safari-gold/#findComment-534976 Share on other sites More sharing options...
November 15, 20177 yr comment_534977 Some good info Link to comment https://www.classiczcars.com/forums/topic/58157-modern-formula-for-safari-gold/#findComment-534977 Share on other sites More sharing options...
November 15, 20177 yr comment_535029 Arden, FWIW, here's a pic of my car taken in 1999 just before I tore it down for the resto. I'd say your test spray is pretty well on target. Jim Link to comment https://www.classiczcars.com/forums/topic/58157-modern-formula-for-safari-gold/#findComment-535029 Share on other sites More sharing options...
November 15, 20213 yr comment_631597 Does this look close to safari gold to anybody else? It's the closest I found at the paint store. Going to paint my front door on the house with this in a satin finish. Thanks for any opinions. Link to comment https://www.classiczcars.com/forums/topic/58157-modern-formula-for-safari-gold/#findComment-631597 Share on other sites More sharing options...
November 15, 20213 yr comment_631611 2 hours ago, siteunseen said: Does this look close to safari gold to anybody else? Always a problem as every flatscreen monitor is different, but it's a bit to yellow? on the 240z (on the rear fender) it looks the correct color .. on the second to last pic) It needs just a little bit more brown? Link to comment https://www.classiczcars.com/forums/topic/58157-modern-formula-for-safari-gold/#findComment-631611 Share on other sites More sharing options...
November 15, 20213 yr comment_631615 It matches pretty close to @five&dime 300ZX build. Link to comment https://www.classiczcars.com/forums/topic/58157-modern-formula-for-safari-gold/#findComment-631615 Share on other sites More sharing options...
