Posted July 19, 20177 yr comment_526121 We almost have Cody's car road ready but he is complaining about too much steering slop. I need to look at it but I wanted some pointers on what too look at and if the steering box can be tightened up? I know to look at the ball joints and wheel bearings but what else? Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/ Share on other sites More sharing options...
July 20, 20177 yr comment_526132 Sorry, but what kind of car is this? Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/#findComment-526132 Share on other sites More sharing options...
July 20, 20177 yr Author comment_526214 72 Datsun 510 wagon Should have put it because it is not obvious it's in the 510 sub-forum Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/#findComment-526214 Share on other sites More sharing options...
July 21, 20177 yr comment_526249 Check the U-joint. Interesting that Nissan offered u-joint rebuild parts for the 510, but did not offer them for the 240Z. If the 510 parts are NLA at Nissan, it's possible that ez-to-source Kawasaki ATV halfshaft u-joints that fit the S30 will also work for the 510. $30 complete (spider, cups, bearing needles, seals, circlips, and grease fiiting) and relatively easy to install. A 64th inch of slop in the u-joint will be greatly amplified at the steering wheel and makes straight-ahead highway driving 'more involving'. Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/#findComment-526249 Share on other sites More sharing options...
July 21, 20177 yr comment_526250 The 510 steering ujoints are the same as the 240 piece. Find the thread about the ATV400 ujoint part number. 510 Steering boxes are problematic to find in good condition. There is a lash adjustment on the top, play with that to get it as tight as possible. Even mine that is nearly slop free with all new ball joints throughout still steers like most 50 year old cars with reciprocal ball steering..... There is a guy making a new K member with a rack and pinion but it requires a front sump engine. Edited July 21, 20177 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/#findComment-526250 Share on other sites More sharing options...
July 21, 20177 yr Author comment_526280 Thanks guys. I will check the U joint and the steering box. So there is no problem in trying to tighten the steering box up? If I over tighten what happens? Heavy, stiff steering or worse? Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/#findComment-526280 Share on other sites More sharing options...
July 21, 20177 yr comment_526286 There's a procedure in the Steering chapter. Â Tighten then back off 20-25Â degrees. Â You can pop out the internals also and pack some new grease in. Â What's there will probably be dried out. Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/#findComment-526286 Share on other sites More sharing options...
July 22, 20177 yr Author comment_526293 2 hours ago, Zed Head said: There's a procedure in the Steering chapter For a Z or a 510? Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/#findComment-526293 Share on other sites More sharing options...
July 22, 20177 yr comment_526294 Sorry, wrong car, missed Post #3. Â There is an adjustment though, a bit more complex. http://www.nicoclub.com/FSM/510/510 Service Manual Chassis and Body/510 Service Manual ST.PDF Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/#findComment-526294 Share on other sites More sharing options...
July 22, 20177 yr Author comment_526297 Thanks! @Zed Head Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/#findComment-526297 Share on other sites More sharing options...
July 22, 20177 yr comment_526314 Only one U-joint in the 510's steering shaft? Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/#findComment-526314 Share on other sites More sharing options...
July 22, 20177 yr Author comment_526354 10 hours ago, Namerow said: Only one U-joint in the 510's steering shaft? there is only one u joint in the steering shaft. Box is on the rear of the cross member and there is not much room there The joint looks good. All the slop looked like it was in the box itself. We already pulled the hubs and greased them. They had a little play too. This is the way I adjusted the box.: Roll the car forward a few feet, to make sure the wheels are pointing forward. Then, take a wrench and loosen the jam nut on the top of the steering box, AT THE SAME TIME, put a slotted screw driver into the slot in the top of the screw, AND HOLD IT IN THAT POSITION! Now, carefully screw the screw down in the box, till you feel some resistance. ( you may have to back the nut off a hair more, to keep it from tightening up) Then, go grab the steering wheel and wiggle it back and forth, WHILE WATCHING THE WHEELS. You want to see the wheels move, with the steering wheel movement. IF not, tighten a bit more. When it seems ok, hold the screw in that EXACT position, and then you tighten the jam nut! Now, this is whre you find out if your worm and sector gears are bagged beyond adjustment. You have to drive the car, to see if it wants to return to center, AFTER you try to turn a corner. IF it is sluggish, or just plain TOO TIGHT, you have to back OFF the adjustment, till it turns ok, but, if you loose the on-center tightness...YOUR BOX is dead. You will either have to live with that vague steering, try and find a better box, or, try to find a good HL510 box and put that on. So try a few points , test drive.....GOOD LUCK! While you can turn the wheels statically, I do recommend you actually drive the car to really see how it's working, and BECAREFUL when you first turn, as you may be surprised at how tight the box can become, past the on-center feel. We did all this with the car in the air. Now time for a test drive... Link to comment https://www.classiczcars.com/forums/topic/58159-steering-box/#findComment-526354 Share on other sites More sharing options...
