Posted July 23, 20177 yr comment_526439 I guess I don't know how to search the forums. It doesn't matter what I put in the search box in the upper right side I get 0 results. What am I missing? Link to comment https://www.classiczcars.com/forums/topic/58185-forum-search/ Share on other sites More sharing options...
July 23, 20177 yr comment_526441 Google search works well. Type "site:classiczcars.com" before the search terms. Could also be that you're not choosing "All content" from the drop-down box. Link to comment https://www.classiczcars.com/forums/topic/58185-forum-search/#findComment-526441 Share on other sites More sharing options...
July 24, 20177 yr Author comment_526472 Thanks for the reply. I do use the google search and it works just fine. I was just curious about the forum search because no matter what I try, including All Content in both regular and advanced search, I get zero results. It looks to me like search in the forums does not work. Link to comment https://www.classiczcars.com/forums/topic/58185-forum-search/#findComment-526472 Share on other sites More sharing options...
July 24, 20177 yr comment_526475 On 7/23/2017 at 10:32 PM, w3wilkes said: I guess I don't know how to search the forums. It doesn't matter what I put in the search box in the upper right side I get 0 results. What am I missing? Hi @w3wilkes, the search is functional on this site. It's probably better than Google because it will include hidden areas not visible to non-members. But, you have to select the correct option when searching. For instance, if you have a topic (thread) open, the search will always default to the current topic. Here's what it looks like when I click search while reading this topic, for instance. Notice that it has "this topic" selected... On 7/24/2017 at 3:11 PM, w3wilkes said: Thanks for the reply. I do use the google search and it works just fine. I was just curious about the forum search because no matter what I try, including All Content in both regular and advanced search, I get zero results. It looks to me like search in the forums does not work. The forum search is specific to the area you are in. If you want to search the entire site, you can go to our home page and click search, or, you can just select "All Content" under the drop down, like this: Link to comment https://www.classiczcars.com/forums/topic/58185-forum-search/#findComment-526475 Share on other sites More sharing options...
July 24, 20177 yr Author comment_526484 So tell me what I'm doing wrong... Here's snips of my search and the results. Doing site:classiczcars.com gas cap in Google search I only get 200+ hits on "gas cap" Edited July 24, 20177 yr by w3wilkes add additional info Link to comment https://www.classiczcars.com/forums/topic/58185-forum-search/#findComment-526484 Share on other sites More sharing options...
July 24, 20177 yr comment_526485 Mike does the forum make any money from google? If we use the forums search does it create revenue? Edited July 24, 20177 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/58185-forum-search/#findComment-526485 Share on other sites More sharing options...
