August 25, 20177 yr comment_528833 Awesome! Link to comment https://www.classiczcars.com/forums/topic/58221-starting-problem/?&page=14#findComment-528833 Share on other sites More sharing options...
August 25, 20177 yr comment_528840 Link to comment https://www.classiczcars.com/forums/topic/58221-starting-problem/?&page=14#findComment-528840 Share on other sites More sharing options...
August 25, 20177 yr comment_528845 So it was a bad o-ring around the sending unit?  That was letting air in the system and causing the up and down fuel pressure?  That is a new one to remember for me.  Glad you got it worked through. Way to go Dad!  Link to comment https://www.classiczcars.com/forums/topic/58221-starting-problem/?&page=14#findComment-528845 Share on other sites More sharing options...
August 25, 20177 yr comment_528852 Site, the real issue was stopped up tank lines from the Red Coat sealer. The tank sender leak was incidental Link to comment https://www.classiczcars.com/forums/topic/58221-starting-problem/?&page=14#findComment-528852 Share on other sites More sharing options...
