I need from 1 to a set of 4 original 240Z steel wheels from a 1970 car. Must be date-stamped 70 (for 1970). These wheels are 4.5 inches wide at the tire bead. Can also use 1 to a full set of 4 original 'D' hubcaps from a 1970 car. Call Pete at 250-821-1026, or email: cain@uwo.ca
Thanks!
Can someone put some pictures here from the different steel wheels original for the 240z early and later?  I've never seen them.. (not a really good look) I understand there were small and a bit wider ones..
