Posted August 10, 20177 yr comment_527684 While I've got the dash open for a new radio I thought I'd replace the overhead and map bulbs with LED. Thinking a nice bright for the overhead; https://www.superbrightleds.com/cat/festoon/filter/Base_Type,3110,1,8182: And https://www.superbrightleds.com/moreinfo/festoon/de3175-led-bulb-4-smd-led-festoon-30mm-car/2107/#/attributes/10822 for the map light. Will these work? Link to comment https://www.classiczcars.com/forums/topic/58295-series-1-240z-overhead-map-bulbs/ Share on other sites More sharing options...
August 10, 20177 yr comment_527688 I used the the 3022 for both Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58295-series-1-240z-overhead-map-bulbs/#findComment-527688 Share on other sites More sharing options...
August 11, 20177 yr Author comment_527720 I guess you haven't found the 3022 CAN to be too bright for the map light? Edited August 11, 20177 yr by w3wilkes Link to comment https://www.classiczcars.com/forums/topic/58295-series-1-240z-overhead-map-bulbs/#findComment-527720 Share on other sites More sharing options...
August 11, 20177 yr comment_527721 I like itSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58295-series-1-240z-overhead-map-bulbs/#findComment-527721 Share on other sites More sharing options...
August 11, 20177 yr Author comment_527722 Thanks Link to comment https://www.classiczcars.com/forums/topic/58295-series-1-240z-overhead-map-bulbs/#findComment-527722 Share on other sites More sharing options...
