August 20, 20177 yr comment_528287 Is it possible to put the air intake from the '83 in the '79, and take the cold air intake out of the equation? I drive an 80zx n/a and have an '82 n/a parts car..all that stuff except for the ignition control module and AFM boot are interchangeable. My 80' has 207k miles on it, has 175+/- compression and runs like a Swiss clock. Mileage is not necessarily an indicator of being worn out. Link to comment https://www.classiczcars.com/forums/topic/58344-79-has-less-power-than-my-83-both-na/?&page=2#findComment-528287 Share on other sites More sharing options...
August 20, 20177 yr comment_528295 Did I hear a compression check anywhere? when you are having problems you need to diagnosis and work the issue, not throw parts at it and hope for the best, or take random suggestions made based on limited info. I sometimes will throw out a suggestion but its often wrong due to my having to take a SWAG at the issue due to limited info. Therefore I would recommend: Compression check, fuel pressure, timing just for starters. Tune up consisting of fluids, filters (air oil gas). Oh and a check of valve lash, adj if needed, very easy to do on a Z. Next up would be some new plugs, drive the car several miles then pull them and read for clues on mixture and oil blow by. listen for a misfire if noted do a balance test to find the offending cylinder, work the problem from there, has to be compression/fuel/spark. Resolve and test again. There is a process to diagnosis, the FSM covers most of the problems you are likely to encounter. Common problems are poor fuel delivery due to plugged lines, and poor electrical connections on the FI. Sensors on critical for correct fuel/air mix, a reading of the plugs is a good start for this. forgot to mention, on the bypass as others have noted, if you have a problem with it, you need to correct. Test it to see if it is functioning as designed (added air flow during warm up) using the FSM as a guide. If its malfunctioning replace it. One other item would of course check the vacuum hoses since you mentioned a whistle noise. Vacuum leaks are bad. Make sure the distributer is advancing as designed (there I go with a SWAG). Edited August 20, 20177 yr by Dave WM could not help myself Link to comment https://www.classiczcars.com/forums/topic/58344-79-has-less-power-than-my-83-both-na/?&page=2#findComment-528295 Share on other sites More sharing options...
August 20, 20177 yr comment_528296 He's selling the 79. He was just looking for a simple answer to a complicated question. Link to comment https://www.classiczcars.com/forums/topic/58344-79-has-less-power-than-my-83-both-na/?&page=2#findComment-528296 Share on other sites More sharing options...
August 20, 20177 yr comment_528299 11 minutes ago, Zed Head said: He's selling the 79. He was just looking for a simple answer to a complicated question. Roger, wish I had paid more attention, would not have bothered I had realized he was not interested if fixing it. of course the easy answer is there is no easy answer on second thought, if you are going to have old cars that don't have all the ODB stuff, then the simple answer would be a lot of things could cause the problem and you have to diagnosis it to determine them using proper test procedures and keeping track of results. Edited August 20, 20177 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/58344-79-has-less-power-than-my-83-both-na/?&page=2#findComment-528299 Share on other sites More sharing options...
August 20, 20177 yr comment_528301 5 minutes ago, Dave WM said: on second thought, if you are going to have old cars that don't have all the ODB stuff, Are you a Wu Tang fan? Where does ODB come in? Old Dirty Bastard. Link to comment https://www.classiczcars.com/forums/topic/58344-79-has-less-power-than-my-83-both-na/?&page=2#findComment-528301 Share on other sites More sharing options...
August 20, 20177 yr comment_528302 8 minutes ago, Zed Head said: Are you a Wu Tang fan? Where does ODB come in? Old Dirty Bastard. yikes! had to look that one up. OBD Edited August 20, 20177 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/58344-79-has-less-power-than-my-83-both-na/?&page=2#findComment-528302 Share on other sites More sharing options...
August 20, 20177 yr Author comment_528334 I just want someone who has had this issue, and it could be air fuel ratio, but a smog machine is needed for that I thinkSent from my SM-G900V using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/58344-79-has-less-power-than-my-83-both-na/?&page=2#findComment-528334 Share on other sites More sharing options...
August 20, 20177 yr Author comment_528335 Also timing is perfectSent from my SM-G900V using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/58344-79-has-less-power-than-my-83-both-na/?&page=2#findComment-528335 Share on other sites More sharing options...
August 20, 20177 yr comment_528355 9 hours ago, thetech101 said: I just want someone who has had this issue, and it could be air fuel ratio, but a smog machine is needed for that I think Sent from my SM-G900V using Tapatalk or you could read the plugs, should give a decent idea of A/F mix. all a moot point it would seem. Your looking for an explanation without enough data to draw a conclusion from. Link to comment https://www.classiczcars.com/forums/topic/58344-79-has-less-power-than-my-83-both-na/?&page=2#findComment-528355 Share on other sites More sharing options...
August 21, 20177 yr Author comment_528486 I could but, but I'm looking for someone who has had this, not guesses. It would be nice to figure this out due to there not bring a forum any where without this issue and I'm sure there will be someone else with issue. In addition I just want to sell that car. it would be cool if someone happened to have seen this idle and the issues it developed before.Sent from my SM-G900V using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/58344-79-has-less-power-than-my-83-both-na/?&page=2#findComment-528486 Share on other sites More sharing options...
August 21, 20177 yr Author comment_528487 With the issue*Sent from my SM-G900V using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/58344-79-has-less-power-than-my-83-both-na/?&page=2#findComment-528487 Share on other sites More sharing options...
