280z wiring problems
Gators280z
Ok, so I took on the task of rebuilding my perfectly running l28. I got it out had the motor redone and put it back in. That was all, for the most part, easy. Then I go to start the wiring procedure. I have a diagram and I followed it to the most of my abilities. When I got the car, it had quite a few wires unconnected in the first place so I had left about 4 wires unconnected. So here comes the problem; I have no electrical power running at all through the car.I'm talking no headlights, no dashlights, no start lights. Nothing at all. This is the last step before I prime engine and go. So please if anyone has experience with this or knows what else I can do please comment. Ill explain anything if you have questions. Thank you so much
Sent from my VS995 using Classic Zcar Club mobile
