On 9/12/2017 at 2:46 PM, w3wilkes said:
Bulbs I bought from Superbright bulbs;
2 - 67-CW12-G: Cool White (license Plate)
2 - 67-A12-G: Amber (side markers)
2 - 67-R12-G: Red (side markers)
1 - BA9S-WHP: Cool White (glove box)
2 - 3110-CW18-CB: Cool White (map and dome lights)
All these fit without issue.
The LED tail 1156 & 1157 for tail in the color of the lens (red for tail white for reverse) and LED 1157 for front blinker (Amber) I got from local NAPA store. They all fit fine.
The 2 main concerns I've found online about LED bulb swaps is:
they're not very visible in the daytime
and
the difference between the tail lights and brake lights isn't very noticeable.
Is this something you've found?
At least with the bulbs I got from my local NAPA store for the tail / brake / front marker they're just fine. Plenty bright and the difference from tail to brake / blinker is every bit as good as the incandescent bulbs were. I had heard that also, but I'm very pleased. Wonder if the complaints were from people that had put white bulbs behind a colored lens? I used the colored bulbs that were the same color as the lens I put it behind.
https://www.superbrightleds.com/carbulb_notes.php
Read the "Which color LED should I use"
