not the actual gasket, but a actual size scan of the gasket (and a ruler next to it) that goes between a cannon intake and a weber dcoe 40. i need to make something, but dont want to order a complete gasket kit if i dont have to.
thanks all
Edited by sweatybetty
https://www.classiczcars.com/forums/topic/58393-weber-carb-gasket-needed/
I've got a Weber 40 and Cannon set up on a shelf in my junk room.  I'll get them down soon and see if that gasket is there, if so I can scan it for you.
Looking at this picture looks like I have them.  Give me an hour or so to get to it, just getting up this morning.
27 minutes ago, sweatybetty said:
i really dont want to pull a carb off the car yet. im going to make some phenolic spacers and i need a pattern
Are we talking about the same thing?  Those black spacers in between the carb and the intake?  Looks like 6 individuals to me.  Left and right?
a scan would be perfect :cool: im looking to print it out, cut along the lines and use it as a pattern.
i found the spacers on ebay, but the want $30+ for 2. if i have a pattern, i can make all 6 for about $25
You're gonna have to 'esplain what I need to do as far as scanning what you need. Can you go to "windows paint" or similar, take the first scans I sent and get everything to scale then print that?
site, thanks for the help. not trying to be a pita :D
can you scan it with a ruler or something like a quarter next to the gasket? that would give me a size reference to work with.
here is a scan of 2 dimes that i scanned and saved as a jpeg, then attach as a photo. it should print out to actual size
