Does anyone have any pics of the inner fender panels? My car doesn't have them. I see the bolt hole tabs just waiting for its mate. Could somebody easily replicate them with sheet metal? I just need to see what they look like so at to cut their shape.
https://www.classiczcars.com/forums/topic/58396-front-inner-fenders-77-280z/
Heads up: fiberglass and ABS cement is not a great repair here. I just tried it a couple weeks ago when I pulled the fenders. Whatever plastic Nissan used to make those liners isn't ABS. Solvents like acetone and MEK won't touch it. I suspect it's probably polyethylene or something similar, which is notoriously hard to bond to. Regular polyester fiberglass resin would probably be better: it won't bond chemically, but if you scuff it up first might grip well enough to hold it together.
