Does anyone have any pics of the inner fender panels? My car doesn't have them. I see the bolt hole tabs just waiting for its mate. Could somebody easily replicate them with sheet metal? I just need to see what they look like so at to cut their shape.
https://www.classiczcars.com/forums/topic/58396-front-inner-fenders-77-280z/
This is what they look like. Different to the 240Z version.
Im debating repairing these so I could make a mold and then make a new set out of fibreglass. It's way down on my "to do list".
Finding a set in good condition will be hard.
Oh wow. That's way too much to bend by hand. Damn. I'm gonna need a parts car to get those.
Heads up: fiberglass and ABS cement is not a great repair here. I just tried it a couple weeks ago when I pulled the fenders. Whatever plastic Nissan used to make those liners isn't ABS. Solvents like acetone and MEK won't touch it. I suspect it's probably polyethylene or something similar, which is notoriously hard to bond to. Regular polyester fiberglass resin would probably be better: it won't bond chemically, but if you scuff it up first might grip well enough to hold it together.
I used it on my console where the choke mount had cracked it. It was much stiffer and thick compared to the inner fenders.
Thanks for the heads up, I won't mention that's again as a possible bond. Cliff
I'm thinking that some sort of heat weld (melting) would be a possible repair for pliable plastics.
I'm assuming the fender liners are high density polyethylene, or polypropylene.
ABS would not be a good choice there because it's probably too brittle.
