FI enrichment effects on idle and vacuum.
Dave WM
Dave, Yeah, it's not as bad as it sounds. You can get the whole rail off as a unit, and that will also give you the opportunity to take a look at your lower injector seals. If they're dried out and shrinked up, they might not be sealing well. And that certainly isn't going to help a lean misfire at idle when the vacuum is so high and the amount of fuel is so low.
Chas, Haha! That sure does look familiar! I don't remember, but I probably got the idea from seeing what you did! Out of curiosity, how did you get the injectors to fire?
I first tried cranking, but it would take a long time to get any usable results, and even with the plugs out it would be hard on the starter/battery.
In the end I made a harness with some old connectors. 3 sets of two injectors in series so they would not be running at full battery voltage. Then two aligator clip on the battery. I still have the harness somewhere. Il take some photos of it and post them for reference.
Used a screwdriver through the aircleaner to activate the AFM flap and turned the ignition on to run the pump.
Edited by EuroDat
Chas, That's  exactly what I did as well. I used the starter for about ten seconds and decided I needed to do something different. That's when I got the signal generator out and used it to drive a relay that pulled the lower side of the coil to ground. That way, I could also test the ignition system and verify the one injector opening for every three sparks, as well as vary the frequency. A little crude, but it worked.
I only mentioned the sig gen because I'm sure Dave has one. Probably vacuum tube, but I'm positive he's got one there somewhere.   :)
  • Who's Online   2 Members, 0 Anonymous, 614 Guests (See full list)
