260z Fuse box/wiring harness
Jeff Berk
I purchased this harness thinking my old harness was bad. I was wrong so I'm keeping my old and selling this one. I've cleaned all the contacts and re wrapped it with cloth tape. I added an extra ground wire because I've had problems in the past with the original ground configuration. One connector housing is slightly damaged but still works fine. Most of the terminals have been labeled. This is reportedly off of a '74 with a manual transmission. I tested it out in my car and it seems to work fine.
I'm asking $95 including shipping from Cleveland, Ohio. You can take $8 off for local pickup.
