Need a favor: Measurement ...
JSM
Anyone have their center console out? I need a measurement of the hole (bottom left) so I can replace the rubber boot and center it correctly. I'm hoping this will match up. Unfortunately someone cut up the hole forcing me to use the later rubber instead of the correct one.
Or should I just slide the rubber down with it in neutral and use that as the guide?
Sorry, since my car has no predrilled holes for the later model rubber and flange I need to use, I wanted to get a measurement of one of the holes (lower left) placement on somones existing trans tunnel.  If I have one of hole measurements, the other three should fall right in place when I go to install.
At this point with no holes at all in my trans tunnel, I'm at a best guess to line it up.
Edited by JSM
