Posted September 2, 20177 yr comment_529433 Can't find replacement tube, so, need some help finding the fittings for rebuilding an EGR tube on 77 280z. Need to smog it here in California. Smashed the original when removing the exhaust to run headers. Link to comment https://www.classiczcars.com/forums/topic/58443-egr-tube-rebuild/ Share on other sites More sharing options...
September 2, 20177 yr Author comment_529442 Here's a pic of the entire assembly that I need. Anybody got one? You've got me by the short hairs, will pay dearly. Edited September 2, 20177 yr by rosaluma Link to comment https://www.classiczcars.com/forums/topic/58443-egr-tube-rebuild/#findComment-529442 Share on other sites More sharing options...
September 2, 20177 yr comment_529445 If you can't locate one a hydraulic hose shop might be able to fab one if you can supply or tell them the correct fittings for the ends Link to comment https://www.classiczcars.com/forums/topic/58443-egr-tube-rebuild/#findComment-529445 Share on other sites More sharing options...
September 2, 20177 yr Author comment_529448 Sounds like a solid plan, thank you Patcon. Luckily, I saved the fitting from the exhaust manifold for them to match. I still need to extract the other fitting from the EGR intake. Edited September 2, 20177 yr by rosaluma Link to comment https://www.classiczcars.com/forums/topic/58443-egr-tube-rebuild/#findComment-529448 Share on other sites More sharing options...
September 2, 20177 yr comment_529450 I just looked at my spare motors. I don't have one... Link to comment https://www.classiczcars.com/forums/topic/58443-egr-tube-rebuild/#findComment-529450 Share on other sites More sharing options...
September 2, 20177 yr Author comment_529453 On 9/2/2017 at 5:02 PM, Patcon said: I just looked at my spare motors. I don't have one... Thanks for checking...they are rare. Link to comment https://www.classiczcars.com/forums/topic/58443-egr-tube-rebuild/#findComment-529453 Share on other sites More sharing options...
