Posted September 4, 20177 yr comment_529547 I'm putting my 4 speed transmission from my 240z onto my 280z engine, what do I need to worry about, flywheel, clutch... Thanks. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58453-transmission-and-other-parts/ Share on other sites More sharing options...
September 4, 20177 yr comment_529558 All I can think of is the speedometer gear. Seems like the 4speed is white and fewer teeth. The 5speed is yellow with more teeth. Swap those and your speedometer will stay close to true. Link to comment https://www.classiczcars.com/forums/topic/58453-transmission-and-other-parts/#findComment-529558 Share on other sites More sharing options...
September 4, 20177 yr comment_529559 I said it backwards! Read down about a quarter page for transmissions. http://datsunzgarage.com/engine/ Link to comment https://www.classiczcars.com/forums/topic/58453-transmission-and-other-parts/#findComment-529559 Share on other sites More sharing options...
September 4, 20177 yr Author comment_529564 Thanks Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58453-transmission-and-other-parts/#findComment-529564 Share on other sites More sharing options...
September 4, 20177 yr comment_529572 Link to comment https://www.classiczcars.com/forums/topic/58453-transmission-and-other-parts/#findComment-529572 Share on other sites More sharing options...
September 11, 20177 yr comment_530034 I think you need (or might not need) a pilot bearing for manual trans. Unless it's already there. Link to comment https://www.classiczcars.com/forums/topic/58453-transmission-and-other-parts/#findComment-530034 Share on other sites More sharing options...
https://www.classiczcars.com/forums/topic/58453-transmission-and-other-parts/Share on other sites
