Posted September 4, 20177 yr comment_529603 Ok, first let me say I have had this car since 1979, never had this issue car is a stock motor, running points, with a aftermarket coil since mid 80's a few months ago, I drove the car, ran fine then lost power and died. Open hood checked connections, all tight restarted fine. Has done the same thing three or four times since, always restarted. Changed fuel filter today, went for spirited drive fo 60 miles, all perfect then it did it again. Piulled over, and re;started and here I am st home, wondering what to check next? Seems electrical the way it loses power... temperture does not seem to matter, it has done it on hot nights and cool days> Only thing changed out this year is the battery any advice would be appreciated thanks, bob Link to comment https://www.classiczcars.com/forums/topic/58457-strange-car-dies-and-then-restarts-loses-power-first/ Share on other sites More sharing options...
September 4, 20177 yr comment_529605 Would it go 60 miles before you changed the fuel filter? Mine would make it around the block a couple of times then die. I could pull the supply side hose off the filter and blow into there until I heard bubbling in the tank. Cranked right up and drove home. Drove me crazy. Ended up being a cruddy fuel tank. Do you have a clear filter right out of the tank? $3 for a Fram G2 @ walmart. Easy way to see if you need to clean the tank. Link to comment https://www.classiczcars.com/forums/topic/58457-strange-car-dies-and-then-restarts-loses-power-first/#findComment-529605 Share on other sites More sharing options...
September 4, 20177 yr Author comment_529609 Thanks for the response The new filter looks clean. I changed the filter before I drove today. Old one didn't look that bad, but had been there for years. 'Thinking of checking the the carb filters next. Hate to think the tank is causing this, but it is 47 years old...... also was thinking fuel pump screen? Was hoping for some electrical issue, but may be fuel related. Cant seem to make it stall it again on demand...... Link to comment https://www.classiczcars.com/forums/topic/58457-strange-car-dies-and-then-restarts-loses-power-first/#findComment-529609 Share on other sites More sharing options...
September 5, 20177 yr Author comment_529610 Going to cut open the old filter and see what hind ;-) Link to comment https://www.classiczcars.com/forums/topic/58457-strange-car-dies-and-then-restarts-loses-power-first/#findComment-529610 Share on other sites More sharing options...
September 5, 20177 yr comment_529619 Does it spit or sputter any before it dies? Or does it just die as if someone turns an electrical switch off. If so that sounds more electrical to me. Link to comment https://www.classiczcars.com/forums/topic/58457-strange-car-dies-and-then-restarts-loses-power-first/#findComment-529619 Share on other sites More sharing options...
September 5, 20177 yr Author comment_529622 Cut open old filter, does not look bad, no big rust or particals in filter it deffinetly studders (loses power) before dying. But when I try to restart it right away, starter turns and acts like no spark. Sometimes it runs with the feeling of "missing" then regains power or dies Link to comment https://www.classiczcars.com/forums/topic/58457-strange-car-dies-and-then-restarts-loses-power-first/#findComment-529622 Share on other sites More sharing options...
September 5, 20177 yr comment_529626 Any chance the coil is over heating? What are you running? Edited September 5, 20177 yr by rcb280z Link to comment https://www.classiczcars.com/forums/topic/58457-strange-car-dies-and-then-restarts-loses-power-first/#findComment-529626 Share on other sites More sharing options...
September 5, 20177 yr Author comment_529627 Scary, still have the original box from the coil a "flamethrower" by PerTronix Link to comment https://www.classiczcars.com/forums/topic/58457-strange-car-dies-and-then-restarts-loses-power-first/#findComment-529627 Share on other sites More sharing options...
September 7, 20177 yr comment_529806 Boy I know this feeling. It was my fuel filter. First I could see a small amount on the bottom of the filter. Ran fine on a new filter so I cut the old open and. Could easily see the brown crud. Now I carry a spare. When you let the pressure off the crud falls to the bottom. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58457-strange-car-dies-and-then-restarts-loses-power-first/#findComment-529806 Share on other sites More sharing options...
September 8, 20177 yr Author comment_529926 Well, my old fuel filter did not look bad, as I cut it open and looked inside. The filter has been on the car for years. At least since my last tune up. The new one looks clear, and I don't see a drop in fuel level in it either. I just replaced the coil this morning, and I have driven ten miles so far, and it has been fine. I am not going to say it's fixed, but I hope so. Will report back after I get some miles on it...... Gives me a good excuse to go for a drive. Thanks Bob Link to comment https://www.classiczcars.com/forums/topic/58457-strange-car-dies-and-then-restarts-loses-power-first/#findComment-529926 Share on other sites More sharing options...
September 11, 20177 yr comment_530027 I had an issue like this. Had to pull the gas tank and have it "boiled" out. they also cut out the OEM metal (nonreplacable) screen. No problems since. Common issue with Z's. Also install a Fram G3 filter between the tank and the stock filter. Link to comment https://www.classiczcars.com/forums/topic/58457-strange-car-dies-and-then-restarts-loses-power-first/#findComment-530027 Share on other sites More sharing options...
