Posted September 9, 20177 yr comment_529982 Wondering if anyone has installed a Stahl header? If so, have you had issues with the steering column clearing the header?  Sent from my XT1585 using Classic Zcar Club mobile   Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/ Share on other sites More sharing options...
September 10, 20177 yr comment_529984 Yikes - looks like an Octupus is trying to swallow your steering column. Don't like the proximity to the brake valve Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/#findComment-529984 Share on other sites More sharing options...
September 10, 20177 yr Author comment_529986 Yes I as well not liking that.... Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/#findComment-529986 Share on other sites More sharing options...
September 10, 20177 yr comment_529987 Is that header intended for RHD vehicles? Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/#findComment-529987 Share on other sites More sharing options...
September 10, 20177 yr Author comment_529989 Is that header intended for RHD vehicles?Good question. I do not know as I bought it (and the motor) used (but never fired) . I am doubting it....and am wondering if that would even matter ( wouldn't be 180 degrees on the other side....)?Sent from my iPad using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/#findComment-529989 Share on other sites More sharing options...
September 10, 20177 yr comment_529996 10 hours ago, GV Z Car said: am wondering if that would even matter ( wouldn't be 180 degrees on the other side....)? Â RHD cars had the steering shaft on the other side of the engine but the header would be in the stock position, that header could have been made for a 280z where the brake switch assembly is up on the firewall and you may have to do that. Is the steering shaft actually touching the header? You might get away with a shim under the D/S engine mount and/or you could also cut and weld a notch into the header pipe. Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/#findComment-529996 Share on other sites More sharing options...
September 24, 20177 yr comment_530893 I asked because the two things that the header hits, the steering shaft and brake valve would not be there on a RHD car. Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/#findComment-530893 Share on other sites More sharing options...
September 24, 20177 yr comment_530897 @Walter Moore How are you doing Walter? Have you started looking for another car yet? Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/#findComment-530897 Share on other sites More sharing options...
September 24, 20177 yr Author comment_530899 Turned out I had the engine mount isolator "arms reversed.Sent from my iPad using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/#findComment-530899 Share on other sites More sharing options...
September 24, 20177 yr comment_530905 Good to hear, always nice to find the easy fix. Stahl headers are getting hard to find. Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/#findComment-530905 Share on other sites More sharing options...
September 24, 20177 yr comment_530957 21 hours ago, GV Z Car said: Turned out I had the engine mount isolator "arms reversed. Whoops, glad you found the problem. Â Do you have pictures of the final assembly? Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/#findComment-530957 Share on other sites More sharing options...
September 25, 20177 yr Author comment_530986 Sent from my XT1585 using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58493-any-install-a-stahl-header/#findComment-530986 Share on other sites More sharing options...
