New Engine on the way, what to do .....
Stanley
... with the old engine ? No place to store it. Can't put it behind the barn with the rest of the engines since there are no barns around here. No spare time to shop it around.The Y-70 head (favored in NZ for dirt track cars, or so I've read) may be worth some bucks so I'll save it, but the stock block with 145 K miles and maybe a broken oil ring might not be of great value, so I guess it's adios and sayonara, unless someone has a better idea.
Also, the R&R shop can install headers. Saw this at MSA: http://www.thezstore.com/page/TZS/PROD/classic19c/15-6017
Says it's for 81-83 280zx. New motor has P79 head so should be OK? Will be re-using the SU's. Mix and match ?  That header sure has an ugly merge pipe though, unless turbulence is good.
  • Who's Online   1 Member, 0 Anonymous, 292 Guests (See full list)
