Hi Jeff, my son and I are still greatly enjoying your builds. One question though, after grinding on your rods to balance them are you planning on doing any kind of stress relief like polishing or bead blasting?
No, basically that is it for me. I am not too worried about the light sanding I have done, and I don't think I have made any crazy weak points to worry about. The engine is not going to be under a huge amount of stress anyway, as I will be running the factory rev limit.
Jeff, Did you put some sealant at the main rear cap parting lines? those side seals can leak if you don't add a little sealant in a couple of places. I may have missed it in the video
Yep. I briefly mentioned it, but I am following the book 'how to rebuild your L series engine' so hopefully it all goes together the way it should ?
This week I finish off the head assembly and mount it to the block. It is coming together and I am getting excited.
Edited by Home Built by Jeff
Time to celebrate!  An appropriate song: Head On!
JAMC!?! You're even cooler than I thought!
Sent from my SM-G950U1 using Tapatalk
